Replaced front brake hoses. Air in system
twfmvm
92 ford ranger 2wd
Ok so I just decided to go ahead and replace my front brake hoses, I've been noticing it seems like the brakes will just barely pull to one side. A mechanic friend of mine said to replace the soft hoses before anything else, he's seen them be diagnosed as bad calipers/cylinders.
After reinstalling the new lines and bleeding the system (multiple times) I'm still unable to get air out and the brake pedal is going straight to the floor.
Do I need to bleed or replace my master cylinder? Or do you think it could possibly something else?
I'm almost at the point where I just want to roll over and pay a mechanic to do it.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Google: gravity bleed brakes
Very simple for one person to do, just takes some time vs power bleeding(pushing down on pedal).
But we are not talking hours, lol, 20-30minutes
twfmvm
Interesting. I'd thought that may be a good solution, but I heard it can sometimes cause air to get into the RABS valve. Could that possibly be the problem as well?
Edit: after reading a bit more about gravity bleeding I think it would be a good way to see if there is actually air I the system
Sent from my SAMSUNG-SM-G890A using Tapatalk
RonD
Official TRS AI
8,370
canada
Rear ABS wouldn't be effected when doing front brake bleed.
But no it shouldn't effect ABS in any case.
Members online
Today's birthdays
Shran
April Truck of The Month
