By passing or eliminating the ABS pump 2001 Ranger?
ben_2_go
340
Third rock from sun
Furd
Engine Type
2.5 (4 Cylinder)
2.5 Scrap
2WD / 4WD
2WD
235-75-R15
None at all.
My '01 Ranger hasn't had operating ABS in nearly 10 years.It was wrecked last September.The truck is doing farm duty now.The 4 wheel ABS module/pump is leaking and sucking air into the system.I took it to a local shop.After they diagnosed and priced the replacement,plus two wheel sensors,I said no thanks.The shop owner said he bypassed his module/pump with steel lines and couplers.He can't do it due to liability.Has anyone done this?
ben_2_go
340
Third rock from sun
Furd
Engine Type
2.5 (4 Cylinder)
2.5 Scrap
2WD / 4WD
2WD
235-75-R15
None at all.
Just a friendly bump to see if anyone can advise on eliminating the antilock brakes on this truck.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I haven't done it, but it is doable. Just re-route the lines around the module instead of through it. At that point it will operate as if it doesn't have ABS.
Staff online
Shran
April Truck of The Month
