No rear brake/turn signal on left side
BAYNE
alright here it goes i have a 1984 ranger with a 89 2.9v6... i have no left rear brake/turn light... running lights work... fuses good... bulbs are good... i even used a jumper wire from the front turn signal to the rear so i would have one ... any ideas would be great
wynnespeed
GA
1995 and 2000
2.3 and 4.0
Socket could be bad.
BAYNE
yeah i changed it also ... i was thinking connection too... then i read somewhere about the turn signal switch in the stearing column
fyre82
Firefighter
6
Lake Almanor, Ca.
2.9/4.0
9" on the 2000, 6" on the '88
265/75/16, 31x10.50x15
The memories of a man in his old age are the deeds of a man in his prime
I suggest that you open up the cowling on the steering column and start with a little plastic friendly contact cleaner in the switch itself. Check the plug for loose/burnt wires, clean and grease the connections.
Check switch operations and use your multimeter to check the circuits starting at the switch.
Be aware that the multi switch takes a little dielectric grease inside to make it work smoothly, that grease will gather crud over time or get hard or chalky.
I have one that has set and is starting to act up again from dust bunnies and crud in it. Seems I have fiddled with this switch periodically since I have owned the truck.
Good luck
Rich
BAYNE
thanks for the reply .. ill check the switch in the column and go from there... i have another question ... have you ever experienced or heard of a fuel pressure regulator taping... my intake manifold was leaking and i replaced the gasket and now i can hear my fpr making a taping sound.. i used the old screwdriver to the ear technique and its definatly coming from the fpr
BAYNE
thanks for your help ... i traced all the wires checking continuity to it and it ended up being a really dirty connector plug coming off the wiring harness in the engine bay... should have checked this first, kinda feel stupid...but atleast its fixed
a31ford
Electronics GURU
26
Brandon, Manitoba
Hey... we ALL have moments.... Just WHY do I have more then most people.....
Greg
