2.9 to 4.0
echo
FORD
Can anyone tell me if the 2.9 and 4.0 share the same bolt pattern for there transmissions. I'm considering putting a 99 automatic behind my 87 2.9l motor. Is it possible? Will I have electronic issues as well?
RonD
Official TRS AI
TRS Technical Advisor
8,367
canada
2.9l and 4.0l(OHV) have the same block so yes the bolt patterns would be the same.
Yes will have issues with the computer when switching from, I assume, current A4LD to 4R55E
read here:
http://www.therangerstation.com/forums/showthread.php?t=145953
And thats 4.0l to 4.0l not 2.9l which adds another layer of issues
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The A4LD to 4R/5R swap is possible.
If you have to ask questions about it then you are not going to be able to successfully complete it.
Staff online
Shran
April Truck of The Month
