pulled the plug wire still runs the same
jrskaggs79
pulled the plug wire still running?
I have a 90 2.9 it runs really rough but will idle in park. I tested. Coil wire and plug w meter all good. Truck was running i took off #6 cyl wire and it didnt miss a beat. Any help eld b appreciated
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
If pulling #6 didn't change anything you probably have a miss on 6.
Have you checked or changed your plugs lately? Even a good mis-gapped spark plug can cause a miss.
Also good to check spark on the suspect cylinder.
jrskaggs79
Getting fire...at plug over 12 volts
tmcalavy
8
Ranger
Do a spark and compression check on all cylinders. Is No. 6 firing all the time? Maybe, maybe not.
jrskaggs79
Compresion is even on all cylinders. Could it be the FPR or the ECM?
jrskaggs79
I have a 90 2.9 it runs really rough but will idle in park. I tested. Coil wire and plug w meter all good. Truck was running i took off #6 cyl wire and it didnt miss a beat. I alsio checked the compression it was even on all the cylinders. Any help would b appreciated
ab_slack
TRS Banner 2012-2015
12
New Joisey
2.9L
If pulling the wire on any other cylinder besides that one makes it work, it seems that be the problem cylinder.
If that is causing the miss I would first think bad plug or wire but it may be worth checking in the distributor cap for dirt or anything odd around that cylinder's wire.
If not spark, then the fuel injector for the cylinder. That could be the control signal to it or it could be the injector itself.
shane96ranger
221
Utah
Ford F150-Stang
Engine Type
V8
4.6 Triton / 5.0
Uh yeah... you should be getting something to the tune of 30,000 volts at the spark plug. Was that what you meant by "plug"?
Staff online
Shran
April Truck of The Month
