How do you adjust transmission bands?
schultp
I have a 1995 3.0L automatic that once in a while won't slip into "D" after backing out into the road from the driveway. I remember reading that sometimes there is an adjustment to the "bands" that will help. Anyone have a how-to to get this done? Any way to properly diagnose that this is the issue?
Paul.
Uly The Hermit
Do these specs (10 ft/lb and 2 turns out) also apply to the 1999 Ranger with the 3.0L and 4R44E transmission? I read somewhere it's supposed to be 1 1/2 turns out but could not verifiy this.
What does "intermediate" mean? Is O/D only overdrive or does that stand for Overdrive/Drive?
Is the "intermediate" band the one closest to the shift lever?
Thanks.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Thanks.
No it does not apply to the 4r44e. You still need to do the 10 ft lbs and back it off 1 1/2 turns. The intermediate band is the rear one. If you're under the truck adjust both bands and not just one.
Uly The Hermit
Thanks. I've been searching for this info for a long time. OP didn't say which trans he had.
