tippykid98cztom
- Apr 30, 2009
- Reaction score
- 0
- Location
- easthampton
- Make / Model
- Ford
- Engine Size
- 3.0
- Manual
origional post: http://therangerstation.com/forums/showthread.php?t=80333
gave it another shot trying to get my relay to work for my 4 hella 500w lights. i tested it with a meeter. it has a good ground, it has constant power, and when i flip the switch there is power to that pole on the relay. only pole that dosent show any power is the load which is to my lights. i tryed 2 relays and its the same with both. what is the problem? or how can i test the relay.
I just looked at my fuseblock that the #30 wire whick is constant power runs to and the fuse was blown. I put another 40 amp fuse in and fliped the switch. it took about 4 seconds then blew the fuse. what do I do?
