Will we damage the 3.0 if we keep using it?
schultp
So, we bought this 1995 Ranger XLT a month ago. I know it either has a blown headgasket and/or a cracked cylinder and/or a leaking intake manifold. It loses coolant internally and has a white smoke from the exhaust.
I completely replaced the cooling system (new radiator, hoses, water pump, thermostat, and several flushes). It now stays at about 50% on the temp gauge and runs great!
My son drives it to and from work and checks the radiator and tops it off every day. We lose about a quart of coolant every couple days.
I want to wait until he returns to college in September and then I'll pull the heads and take a look. But, my question is: Will we damage it further if we continue to let him drive it as his commuter vehicle?
TIA,
Paul.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
Engine Type
V8
6.6L
2WD / 4WD
5"
35"
Yes, the antifreeze is probably pouring into the crankcase, it is like mixing oil and water and will ruin your bearings. If you want to save the motor, stop driving it pronto.
Mutant Pony
Solid Axle Swap
9
Hersey, Mi
2300
TIA,
Paul.
Yes, If the engine is burning antifreeze it will cause major damage to the engine. Antifreeze in the cylinder will erode the cylinder,piston,plug and valves away. Antifreeze it the oilpan will strip the bearings and eventually cause seizure.
My suggestion is to drive it until it quits and then replace the engine with a good used one. Low mileage 3.0s are cheap in the junk yards. All vulcan 3.0s interchange. The old ones like mine don't crack heads... EVER.
samsonitesamsonite
3
Bellingham, Wa
Jeep
2.5
I agree with mutant pony except that I would replace it with a 4.go because mileage is about the same and the power gains you will have are great
schultp
Funny thing is that the oil has no frothy, milkshake look to it. It is almost as if there must be a direct leak of the coolant into a cylinder with no mixing of oil/coolant occurring. If this is true would it then be safer to keep driving??
Paul.
samsonitesamsonite
3
Bellingham, Wa
Jeep
2.5
still no cigar, yes, its a little better than going in the crankcase, but its still very hard on that one piston or pistons and its/their rings.
almostclueless
3
ford
Answer is, it depends....
If it's just a bad head gasket, the engine could end up hydrolocked or warp a head.....not worth it to keep pushing it.
southernlifttruck41
Monticello, KY
ford
Why take the chance. You should be able to replace a head gasket in one day. Two at the most. Ground the truck for repairs. Why destroy a good moter if you don't have too. or '' Captain you have given her all she's got, She can't handle worp speed any longer" Scotty.....LOL
StevesRanger
1999 3.0 Flex fuel
I have been told that you cannot replace a 3.0 flex fuel with anything other than another 3.0 flexfuel. The vehicle mfg date is crucial too. Anyone know if this is correct? Also cannot find rebuild kits for this year,model,type. Please help.
Mutant Pony
Solid Axle Swap
9
Hersey, Mi
2300
You need to start a new thread instead of hijacking one. You will get better results.
schultp
It appears the coolant loss has subsided. I had run the engine and tried to 'burp' the system back when I had rebuilt the cooling system. I thought I had gotten all the air out. I'll keep track of the coolant but I now think we just needed to get all the air out of the system.
I did buy a gasket set on ebay. If there is even a small amount of coolant loss I'll replace the head gaskets.
Thanks for all the advice.
paul.
Mutant Pony
Solid Axle Swap
9
Hersey, Mi
2300
3.0's do trap air really bad. I've pulled the temp sensor and still had trapped air.
If it is not making a white cloud behind you of blowing the coolant out of the reservoir then you do not have a blown head gasket/cracked head.
If you continue to lose fluid then you need to pressure test the system and find out where the leak is.
ZMan
Forum Staff Member
MTOTM Winner
406
Medina, Ohio
Ford Rangers
Engine Type
2WD / 4WD
2WD
Total Drop
4/4, bagged
I really wish people would quit saying the gas mileage is the same.
MY 4.0 has NEVER gotten the 25mpg on the highway my 3.0l does!!!
Wicked_Sludge
42
Westport, WA
3-point-GO
that does get annoying.
call me when your 4x4 4.0 gets 24MPG without babying it (or at all).
rickcdewitt
5
nor-cal
ford
4-0 swap
if you want to park it do an oil change while the motor is warm to get the corrosive glycol out of the oil.then drain the water after firing it up for 30 seconds or so to circulate the fresh oil.if you wanted you could pull the plugs and squirt a small amount of oil in each cylinder also.if you pull the motor apart its a good investment to have the heads checked for cracks and straitness before putting it together so you dont waste your time and parts.if you arent going to fix it right away this is what i'de do.also sometimes a water leak is small enough that the engine heat evaporates the water and you dont notice it in the oil.the glycol still ruins the bearings and stuff though.
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
