Knock Sensor
bootleg
Verbena, AL
2.8 v6
mine is busted, and it seems an impossible-at-best little thing to find. is it really worth the search? or am i chasing a shadow?
RobbieD
2.9l Mafia
3,432
Georgia
Mine broke, too, and I never replaced it. Can't really tell that it makes a difference, not being hooked up.
enginepaul
12
Northern California
2.8
You need it if you have the original ignition.
If you're asking location: Lower Drivers side toward the rear of the block.
It sounds like you need a manual too.
bootleg
Verbena, AL
2.8 v6
Ha! No, I know exactly where its located...what I meant by hard to find is where to buy. I re-soldered the original, but it has seen it's last day. i don't see any difference with it disconnected...ignition is original.
HDCowboy
2.8ltr bored .030 over
Check out www.northernautoparts.com P/N: 5S2203
I spent about 3 months looking everywhere else, then checked out northern and found the knock sensor for 2.8ltr fords
kimcrwbr1
46
maplevalley WA
2.8l
You may get lucky and find one at the bone yard but not very likely. I am just guessing on the price before clicking the link my guess is around $110 new if you can find it.
kimcrwbr1
46
maplevalley WA
2.8l
Wow that is crazy cheap if you buy it be careful on how much you tighten it. The best way to test if it is working is with a timing light watch the timing marks while the engine is running have someone tap on the block with a big wrench right next to it the timing should retard with the tapping. It will throw a code if it is not working during the goose test. If all your computer stuff is working correct the knock sensor will noticeably improve performance and fuel mileage. It constantly monitors detonation and retards the timing under a load then as the vacuum pressure raises MAP it advances the timing accordingly.
kimcrwbr1
46
maplevalley WA
2.8l
Dont tap on the sensor you will need a new one they are very brittle.
enginepaul
12
Northern California
2.8
RockAuto is about $35. - as someones said - get a manual. Testing by part replacement gets expensive.
All parts need to work together for the best results.
HDCowboy
kim- i was surprised at the price as well when i ordered it. I wouldnt have even been looking for it in the first place but the kid that was working on it for me while i was not around broke it among other items costing me more $$$ for my rebuild.
kimcrwbr1
46
maplevalley WA
2.8l
They are torque sensitive too much or too little will throw a false signal. GL
6or9
Rock auto is like walmart
