87 ranger lift or leveling kit?
ranger_redneck
2.9L HOPING FOR A SWAP SOON
i have a 1987 ford ranger 4x4, id like a little more height front and rear, but want the front to sit level with the rear, should i go with a 2" BL? how would i get the front to sit level with the rear? just buying a kit?
Or what other options are there?
bbbc3
51
Tulsa, OK
2.8 V6
ranger_redneck
looks good! i just want enough clearance to put some 235/75/15s on all around with the new wheels i got.. i have like 225/?/15s on it now and would like to go a little bigger for now.
Do you have the link for the kit you bought?
Also, how hard was it to install?
bbbc3
51
Tulsa, OK
2.8 V6
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
The hardest part is getting an alignment afterwards. You'll probably need new camber/caster bushings to straighten it out.
Putting the springs in is as simple as:
Loosen lug nuts.
Jack the truck up by the frame until the wheel is off the ground.
Remove wheel.
Remove the big nut holding the bottom of the coil spring in. (1 1/8 wrench works ok or use same size socket and enough extensions to reach through the middle of the spring.)
Turn the spring to release it from the top. (You might have to remove one side of the shock mounting to get enough droop.)
Pull the old spring out.
Reinstall in reverse order and go do the other side.
ranger_redneck
how about just leveling spacers? thats basically the same proccess not?
where would i even go to find a leveling kit for my ranger?
SenorNoob
569
Middle Tennessee
245-70-R16
Pretty much the same, just put some appropriately sized washers under the spring. Be careful though too much and it may not align. I ended up with a 1" stack on each side for about 1.5" of lift. (Guessing there cause mine was done at the same time as a D35 swap.)
The springs bbbc3 posted do the same thing just in a little different way. (Actually the "right" way I suppose, but the washers work.)
ranger_redneck
awesome! then i dont have to buy a "kit" thanks all for your advice!
