adjusting bands in 4r44e
dizman
i have a 95 ranger 3liter with an automatice its slipping in between shift from second to third and was told the bands need adjustment. i have never did this but am wannting to try it . can anyone give me some info like where the adjustments are made and the proper way to do it also what parts would be needed thanks in advance
Ford Shop Manual said:
NOTE: Procedures are the same for O/D and intermediate band adjustments.
CAUTION: Do not allow adjustment screw to back out. Band strut could fall in transmission assembly.
CAUTION: Throw the locknuts away. The locknuts are not reusable for assembly.
Remove the overdrive and intermediate band locknuts and back off the band adjusting screws.
CAUTION: Install, but do not tighten, a new locknut on the band adjusting stop. Apply petroleum jelly to the locknut seal.
CAUTION: Servos must be installed prior to band adjustment.
Tighten the band adjusting stop using Band Adjustment Torque Wrench Set T71P-77370-A. The wrench will click at 14 Nm (10 lb-ft). Back off the band adjusting stop exactly two turns and hold that position. Tighten the locknut to 47-61 Nm (35-45 lb-ft) using a 19mm wrench.
There you have it.
Kirby N.
March Truck of The Month
