2.9l rebuild and cooling sytem questions
bert0427
GA
ford
2.9l
I have a 86 ranger I am rebuilding the engine (2.9l) I am hoping to put an electrical cooling fan and I was hoping some one could help guide me in the right direction.. I am all ears about the rebuild and also cooling system tips bc I don't want my heads to crack, like I keep hearing, when I get it back together. any advice would be great
RonD
Official TRS AI
TRS Technical Advisor
8,369
canada
The '86, '87 and '88 2.9l heads were the ones that cracked easily, might be best to find a set from an '89 -'92 2.9l, they had a new design that was less prone to cracking.
But any head can crack if overheat, I did my 4.0l, NEVER EVER try to "just make it home", pull over and wait, "time is money" and in this case the longer you wait(for it to cool off) the more money you will have in your pocket :)
Good read here on the 2.9l engines: http://www.therangerstation.com/tech_library/2_9_Page.shtml
Rebuild will be pretty generic, no real surprises, for sure change the cam bearings
sjr53
2
Grand Forks North Dakota
2.9L
Make sure to disassemble the rocker arms and clean out the shafts. They get plugged up. If you remove the end caps of the shafts, a 9/16" plug is the size needed the replace those you need to drill to remove.
bert0427
GA
ford
2.9l
That was awesome information on that page thanks RonD I was hoping to also help cooling with an electric fan what your input on that?
bert0427
GA
ford
2.9l
SJR53 ... when cleaning the rocker assembly should I replace any of the parts also I was going to relace the cam and lifters but was hoping to use the same push rods and rocker arms... thanks for any advise
RonD
Official TRS AI
8,369
canada
sjr53
2
2.9L
I didn't replace anything on mine, but flipped the slightly damaged shaft upside down to put the pressure on the still smooth side of the shaft. The Ford repair manual said there was a difference and put the notch on the shaft end downward, but there was no notch and there was no difference in the holes in the shaft by turning it over. There must be a different shaft that had different holes from top to bottom. The rockers do have 2 holes that aren't in line with each other.
Also note that the center rocker pedestal isn't dead center so it is possible to assemble it wrong and have to take it all apart and redo it. The pedestals bottoms are not symmetrical so watch which way to slide those back on also. I don't know if it matters, but there is a difference on how they are shaped.
drsvox
Prattville, AL
V6 2.8L
I have been there and done that...
If you don't replace any of the rods, lifters, or rockers, be sure you label where you took them from (I use numbered ziplock bags) so you can put them back in exactly the right place.
[edit] and that said, if you put a new cam in, I would def put a new set of lifters in. that's what I did on my 2.8: new cam and lifters, but not new push rods and rocker assemblies.
Staff online
Today's birthdays
Shran
April Truck of The Month
