- Sep 22, 2007
- Reaction score
- 7,419
- Location
- Michigan
- Make / Model
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 177 CID
- 2WD / 4WD
- 2WD
- My credo
- A legend to the old man, a hero to the child...
87 Ranger 2.9.
What are the symptoms of a bad ecm?
I changed everything out in the EGR system trying to get rid of a code 33. Originally i cleaned everything and thought it went away, but it came back.
I swapped over everything from rusty #1s EGR system. Half ass maybe but it ran good....
So i swapped the valve, the black control sensor, and the vaccuum solenoid. It did make an improvement somewhat, but ive had a code 32, a 33, and a 34, that seem to float around. Im also getting a code 41 for a lean O2, that also comes and goes, and sometimes a code 21? Whatever says the coolant sensor is low on voltage, once again, it comes and goes, and every once in a while i get a code 11.
So after all this i swapped out the ignition module, just for shits and giggles, again off rusty #1.
Now, during the KOER test my code reader is showing CM codes, and will not pick up on the number of cylinders of the engine.
Im also getting a high rpm/under load missfire. The low end bogging seems to be somewhat better but its still not like it should be.
Im just wondering if its possible the ECM is junk? I dont understand what the hell else can be doing this.
I miss carburators...
Either way, i need some damn help.
