CoreyTilton
- Aug 20, 2015
- Reaction score
- 9
- Location
- Massachusetts
- Make / Model
- ranger
- Engine Size
- 302
- Manual
i knooooowww. hahaha. its starting to be Drive around with the windows down -weather.
and quite a bit.
i pulled the hole dash, made a custom sheet metal face, and am doing a custom gauge cluster with new AutoMeter gauges.
i yanked out the steering column and stripped it down, so everything that was on there column is getting transferred to a QuickCar ignition Panel and a handful of other free floating QuickCar Toggles. I already put a new fuse box under the hood that im going to start transferring everything over too. already have that hooked up with the battery relocation in the bed. all my main positive and negative leads done.
but still need to wire up the gauges, the ignition panel (turning on switched power, fuel pump, fan, starter), plus horn, wipers, directionals, headlights, all that fun stuff.
- corey
and quite a bit.
- corey
