Valves chatter too bad when timing is set correct ?
raggedyann
ford
1990 2.9 ranger
I can set the timing with my timing light and get it right on the 10 degree mark but the valves chatter too bad unless I back it down about an inch from the mark.
Yes, I unplugged the spout wire when using the timing light.
I cant think what would cause this rather than too much play in dist. shaft ??
raggedyann
ford
problem solved. the pointer at the timing marks was bent. I used another one.
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Thanks for the update.
Staff online
Today's birthdays
Shran
April Truck of The Month
