If transmission is coming off, what else can I do
UAFS
Monterrey Mexico
2.9L
Hi guys,
I just bought a 1988 4x4 Ford Ranger. two hours after I paid for it (cash) the clutch started making some noise. I figure some broken springs and probably need to replace clutch disc assembly, clutch cover assembly, release bearing, pilot bearing, clutch linkage assembly and probably the flywheel.
I want to know what else I could take care of while I'm lowering the transmission? will this give me clearance to remove the oil pan? seems to be leaking some oil. I'm just looking for some general ideas to take advantage of removing the transmission.
thanks in advance.
-Uriel
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Trans removal will not allow for oil pan removal.
It will give access for rear main seal replacement.
Ranger's use a hydraulic clutch, so no linkages, but the slave cylinder is internal to the bell and should be replaced while you are in there.
I usually change the trans fluid when dropping the trans for clutch replacement.
ATX
11/2014 MTOTM Winner
MTOTM Winner
2
Austin tx
5.0
Built not bought
Check the freeze plugs for sure , also rear pinion seal since driveshaft is off . Check u-joints for play . Tailshaft seal . Off the top of my head
I just wanna go fast [emoji48]
Spott
TRS Banner 2012-2015
21
SE Idaho
Engine Type
2WD / 4WD
It might be worthwhile to replace your exhaust manifold outside gaskets and mounting hardware, because disconnecting that Y-pipe makes pulling the transmission so much easier.
Also, you might look into the 4.0 clutch swap; it'll give you a larger stronger clutch, but you'll have to replace the starter as well.
UAFS
Monterrey Mexico
2.9L
thanks a lot everyone. I´ll take all those suggestions into consideration and I´ll let you know how it goes once I gather all the parts.
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
