How to fix "NO HO2S Switching" - code 41
dlance
The title says it all. How is this DTC addressed? New parts? Which ones? Truck does have an issue at idle.
1990 Ranger 2.9l V6
Thx,
Lance
Wicked_Sludge
43
Westport, WA
3-point-GO
check for vacuum leaks, replace fuel filter, varify fuel pressure.
Psychopete
29
FW, IN
+1
I had a gnarly leak at the very back of my upper plenum where it met with the intake. It ran rough at idle, "popped" out of the intake intermittently and threw that code. I reused the gasket and it eventually started leaking. Could very well be a vacuum line as well. Vacuum gauge will show leaks (or low vacuum readings), or spray as many connections as you can with carb cleaner. If the idle surges, there is a leak there. Misfire can also cause a 41, when was the last tune up?
Pete
