HID install in Projector lights
UrbanRedneckKid
Solid Axle Swap
17
Cass Co, Missouri
4.0L
I bought 2 HID kits, from http://www.vvme.com 9007 & H3 both single beam. I opted for the 6K sets, because I would rather have more lighting performace than the bright blue color.
I used the regular lights as high beams and the projectors as low beams.
The projector housings have a shield in them that only allows light to shine down, thus they make a perfect low beam for HIDs.
These are my old "xenon" bulbs. They worked ok, even with mud on them. But there was much need for improvement.
This was the origonal H3 bulb, this happened after 5 min of first being turned on. Somebody must have touched the glass at the factory.
These are the modifications needed to be done to the projectors to run a HID bulb. First, you must drill a 11/16 hole in the tail cap of the housing, then cut a notch so you can slide the wires through it. Then you need a spacer to hold the bulb in, I made mine from a piece of clear tubing (vacuum or fuel hose would work too), you must have a slice in it to put it around the end of the bulb.
Put the bulb in the back of the housing. Make sure it is completely seated and square in the housing. Then add your spacer.
Then put the tail cap back on, and tighten up all the screws.
This is what it looks like all done. the other bulb installs just as the origional ones do.
This is where and how I mounted the ballasts for the drivers side. Note that I labeled the boxes "H" and "L" for easy ID if I run into problems later on.
And this is where I mounted the passengers side ballasts. Labeled as well.
The Wiring...
The high beams/9007s: all your have to do with these is swap the pin from the left side to the right side of the plug on the bulb end of the harness, the middle pin is the ground, dont do anything with the middle pin. This makes it so that this bulb is turned on by the high beam instead of the low beam.
The low beams/H3s: The red wire of the 3 in the headlight plug must be cut and stripped, crimp/solder a male spade connector to it. That is now the power wire to run these as low beams. Then you must run a ground wire for each of the bulbs. Now the projectors are wired as low beams.
The HID setup:To wire up the HIDs is so simple you will laugh, no other cutting and splicing. A simple plug and play, just follow the suppied directions, if you think you need them.
It was easier to remove the grill and headlight housings to do this.
Halfway done, Halogen Vs HID
HIDs installed in the low beams/ projectors. Note that then don't glare upwards. Also note how bright they are in a very well lit shop.
HIDs installed in the high beams. Theres the "burn your retinas out" HID performance. Also note that this pic was also taken in a very well lit shop.
aggoodin
Otsego, MN
Ranger
2.3
Such beautiful lights on a rough truck....
I have been on vacation all week. Hopefully my kit is at the door where DHL left it tuesday. I'll find out tonight.
What temp are your bulbs?
UrbanRedneckKid
Solid Axle Swap
17
Cass Co, Missouri
4.0L
What's so rough about her???
Pretty damn nice, for a truck that I wheel the hell out of. She just don't look so good with the grill out.
Both of my sets are 6K
aggoodin
Otsego, MN
Ranger
2.3
It looks MUCH better with the grill in. :)
whitebassbenny
ford
night shot ?? how you liking aswell?
Resurrection Ranger
Upper Hanover Twsp, PA
2.3
I think I just bought the same headlamp style today on ebay. But since I have only 1 9007 bulb for each, what is in the small projector beam part of the housing? I'm only wired for 1 bulb in each being a 1993.
I'd like to do the HID thing one day. I just ordered these housings cause my OE are rather cloudy and don't do much for me at night anymore.
Loud Ranger
5
MN
'95
4.0
what did you have to do to make that grill fit?nice truck btw, those are the lights i want on my black ranger
UrbanRedneckKid
Solid Axle Swap
17
Cass Co, Missouri
4.0L
That's the same way mine were wired, I just swapped the low and high wires in the plug harness, then tapped the pojectors power wire into the low beam wire.
As much as I'd like to be nice and tell you...
You'll notice I'm the only 3rd gen with a good looking grill.
Besides, the pics give it away... Hacksaw
Evan
5
Stevens Point, WI
4.0 OHV
Looks good, but I thought swapping HID bulbs into a non-HID vehicle was illegal. You get pulled over pretty quick in Wisconsin for doing that...
Beanmachine7000
5
Tennessee
4.0L
It is, unless you buy the correct HID specific projectors, which if I'm not mistaken he did...
Resurrection Ranger
2.3
OK.. I just didn't know if the new headlights came with a bulb and wiring harness for the projector part of the lamp or if it was just for looks. I didn't know there was actual wriring to do in the swap of just the headlight housing.
Ranger44
Ford Technician
23
Illinois
FORD
4.0 OHV
LittleHorse
Pryor, OK
2.9L
does anyone make headlight housings like that for an 89-92? I just searched ebay and found a ton of 93+ and even a couple for <88 but nothing in between...
Evan
5
Stevens Point, WI
4.0 OHV
I thought it was always illegal...if a vehicle came without HID from the factory you're not allowed to install HID.
I'm hoping I'm wrong here, because if I am it means I can install HID on my Mustang. I've wanted to for awhile but always thought it was illegal.
LittleHorse
Pryor, OK
2.9L
I hadn't heard that. I'm guessing it would be a state by state thing. Even so that would be hard to enforce with a fleet of patrolman that usually don't know that much about cars, what cars came stock with HID or how to tell.
Staff online
Today's birthdays
Shran
April Truck of The Month
