Gauge install
Well I finally took the time to install my McNally pyrometer/boost gauge.
First thing I did was to swap out the thermocouple that came with the guages for a MCA setup. You can see how much longer the probe is with the MCA which will provide much more accurate temps in the center of the manifold.
I really dislike mounting the boost sensor right on the manifold or charge air piping so I decided to remotely mount the sensor on the firewall and run tubing. I also don't really care for the hard plastic tubing running everywhere so I slide it into some spare vacuum hose I had sitting around.
Here's everything mounted up in the engine bay.
How the gauge looks in the truck
And since I forgot to post pictures of my cruise control stalk install. Seems to work pretty well for me. Haven't hit it once with my knee and have very good access to it. I'll call that a win.
