Any ideas what would cause a RABS code 12?
RedRangerSTX
4.0L V6
My yellow ABS light is on in my '97 Ranger STX with RABS. I grounded the orange/black wire from the test connector with the ignition on and my ABS light flased a code 12 (11 short flashes followed by one long flash), which supposedly means "Low brake fluid level detected during anti-lock stop". I checked the brake fluid and it is full, so I don't understand why it is throwing this code. Does anyone have any ideas what might be causing this?
RedRangerSTX
4.0L V6
Problem Solved
Turns out one of the wires had come out of the sensor connector for the brake fluid reservoir which was not visually apparent without actually pulling the wires lightly. I pushed the wire back into the connector and the light went out:)
Futurefd
Ranger xl
Thanks! this works for me too!
just cleaned up the wires.
Staff online
Shran
April Truck of The Month
