Onboard air and shocks with cab controls (slow internet connections beware)
Quartermile
Guest
DeeZee box, 2000 Ford Ranger, VIAIR Medium duty system, cab controls, easily removable. Here we go . . . day one:
Wiring plug that will be used for power and control wires
Hole for plug
Installed (temporary, going to install everything rough-in, then take apart later and sand/prime/paint
Simple angle iron to strengthen box
Switch panel
Quartermile
Guest
Day 2:
Pulled more wires from the cab to the engine compartment. Didnt get much done today
Quartermile
Guest
Day 3:
Used an angle grinder with a 1/4" wheel to notch out a piece of angle iron to hold relays that will mount on a bolt holding part of the ABS system onto a bracket.
Also got the wires pulled into the dash where the switches will be mounted.
Quartermile
Guest
Day 4: The real work begins
I got the box of goodies today and opened it like a little kid at Christmas :yahoo:
Then I did a little thinking and started piecing it together :icon_confused:
Pressure switch and gauge
Air and remote gauge output
Through box fitting (very jerry rigged :dunno: but it works pretty well
Remote gauge outlet (from inside)
Remote gauge outlet (from outside), above it is the power/signal connector, and to the far left is the air filter for the compressor
Solenoid drain, hose, and muffler
Current progress as of . . .well now its 2:35 AM Day 5
railman
December 2011 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
12
Madisonville, KY
4.0
lookin good.....nice clean work....
l8r, John
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
It looks good.
You should put some kind of shelving in the box on the top of the tank, but leave the compressor open so it can get cool air. That will allow you to use the box for storage as well without having things riding up on your compressor or tank.
Quartermile
Guest
It looks good.
I still have the sliding tray that came with the box. Its just not in right now because it was in the way
Quartermile
Guest
Day 5: Frustration and fittings
High visibility hose so it doesn't get lost or slammed in a tailgate
Drain assembly/solenoid drain
Low drain so the water runs out of the tank
Air out and remote gauge lines
Looked up around 1 AM and went . . .oh . . .what a mess. Cleaned up everything and called it a day
Current progress as of 1:54 AM Day 6 (I work 1:30 PM to 10:30 PM so don't worry, I'm not working THAT much on this)
Quartermile
Guest
Day 6: Pulled wires from bed to engine bay near battery. Used the hole in the front of the box to run the wires through since it was already there and near a hole in the frame that was already there. Made it a lot easier to route the wires.
Quartermile
Guest
There will be a fuse on both ends of the 10 AWG wire for no special reason, just want one at both ends.
Quartermile
Guest
Day 7
Hose and wires in bed with wires terminated
Relay center under hood, pulled a wire harness plug thing out and put a bolt in that holds all this up.
And installed . . . .
Lighted toggles
And installed . . .temporary psi gauge and switch mount . . .want it to run now, getting a little frustrated, so all that finishing touch work on the inside will wait now. Day 8 plans (if I work on it at all tomorrow) are to mount the box to 2x4's and wire everything up. Then I'll be done save for the psi gauge.
Day 7 progress as of 9 PM:
Quartermile
Guest
Day 8 . . . finished wiring, will post final pics when I have everything done. Only have the base left to do
Staff online
Today's birthdays
Kirby N.
March Truck of The Month
