Biggest tire that could fit on stock suspension? 98 Rander 2wd
Cold Dark Shadow
Waseca MN
2.5L
Im curious what the biggest tire i could get away with on stock suspension?
Its a 98 2wd standard cab step side.
Also want to level out the ride height (possibly lift it all the way around a couple inches) but cant find any like coil spacers or anything for it.
Cold Dark Shadow
Waseca MN
2.5L
thanks for the link
any idea on the tires?
Cold Dark Shadow
Waseca MN
2.5L
also on that link some of the links are dead
DesertStorm
The most southern carolina
93 and 94
I have a 3in body lift on my 94. I am running 33x12.50r15 with swaybar removed. No other lift required. Just a little rubbing on radius arms on off camber tight turns.
Cold Dark Shadow
Waseca MN
2.5L
Cold Dark Shadow
Waseca MN
2.5L
Got any pics of the truck?
Seen the one with the 38s on it, looks sick
DesertStorm
93 and 94
The picture is my avatar. I had to take the front swaybar off b/c the tires were rubbing on it. But i get alot better suspension flex now. I dont have any more pics on my computer besides the one I already have on here. I will try and post another.
DesertStorm
93 and 94
heres a pic
3" body lift
33x12.50r15 Wild Country RVT on 15x8 rims with 4" backspacing
Cold Dark Shadow
Waseca MN
2.5L
Cool man, thanks
What lift did you use?
DesertStorm
93 and 94
performance acc. 3in body lift off of ebay. $90. Took about 3 hours to install. Took 5 min to remove swaybar, almost a full day to change gears and add a l/s carrier.
Cold Dark Shadow
Waseca MN
2.5L
What size is a 31" (xxx/xxr15) tire and would i still need a 3" bod lift to fit them?
Members online
Shran
April Truck of The Month
