EhToke
- Dec 3, 2015
- Reaction score
- 0
- Location
- Regina, SK
- Make / Model
- Pickup 2WD
- Engine Size
- 2.3L
Hi, I have a 2010 Ford Ranger 14X,XXXKM's Manual 2.3L.
My issues are that happened today that iv noticed are.
#1: My Temp Gauge : differs from time to time. Its either COLD or above Cold or Normal Temp. "HAS only went to MAX temp like 3 weeks ago and wouldnt gain speed, power so i had to shut it off and later drove home and in the morning had a computer delete the Error code 1299 i think it was. After that no issues for awhile now just recently started having a weird TEMP to it.
"This problem i plan to fix by getting a new therm stat tomorrow evening after work."
#2: Very High Idle : 3000-4000RPMS when in no gear and slowly reduces when i stop/put it into a gear when stopped, When starting to go from a Stop i had to really push the gas and ride the clutch to get it not to Stall/Bog a couple times if i lightly press gas, also iv only had enough time maybe 15minutes and only 'STALL' i originally had was when i started the truck it RPM'd 3-4k and than stalled other than that i managed to milk her home perfectly without stalling by playing the clutch and gas.
Other than this i haven't noticed any other issues that could be a accomplice to whats currently happening.
I haven't changed ANY fluids since buying it two months ago, Sadly been laid off of the bricklayer union shortly after getting a new truck after my original got smashed and money has been tight and just found a job as a roofer. But thats what im aiming todo is a complete fluid change other than brakes and washer fluid.
I disconnected the Battery for some reason someone, sometime ago always suggested that for some reason and i did just out of shits and giggles.
