shannmarshall27
- Jun 11, 2016
- Reaction score
- 0
- Make / Model
- ford ranger xlt
ok here goes. I have a 2.9 v6.. i have had this truck for over a year and trying my best to keep it going. the problems i have had is heating issues. replaced the water pump got some heat this past winter after the heater core. thermostat. radiator lines. but i am still getting coolant blow back into the reservoir. i took out the thermostat tried blue devil for any head gasket issues. did that procedure been doing it for years. no problems resolved. replaced the valve covers for leaking oil. but there reason i am writing today is that i have a serious oil leak in the front. it is all over the motor. i have tried sealers. thicker oil. stop leaks. looks like front behind the timing cover. in that area. the whole front is covered. it looks like below the head and thermostat housing. but leaking down and hitting moving parts and covering the passenger side of the truck.. i am so lost on this truck. it seams nothing fixes the problems. it is a old truck but doesn't seem to follow any logic. i have tried. but am lost on it . replaced pvc valve because i am also getting to much pressure through the system. my break booster when bad. i replaced it. but the connection from the pressure keeps blowing it out. friends have told me maybe the piston rings causing this. it seems i have to much pressure in the system and it is throwing the truck in disarray. i need it to get back and forth to work. need help bad. any suggestions. i am lost. so confused. i have tried to look at posts and things. but no solid answers. i have 5 kids and time and funds are limited. please any help
