tonyzz
- Mar 10, 2018
- Reaction score
- 0
- Age
- 54
Hello, is there another way to check the abs codes. I have tried to connect to the black and orange spade connector and then to ground. The light does not flash. I tried alligator clips a wire with the opposite connector which was very snug and a long wire to ground. No luck. Any help would be great as once I hit the first stop sign the abs light comes on. All fuses in fuse box are good non blown. I turned. To run no start to try to get the codes. Also brake fluid is full and the connector appears ok no lose wires.
Thanks for any help
Sent from my LG-H901 using Tapatalk
Thanks for any help
