94 ranger drums tight
swamprat
3
lexington KY
Engine Type
4.0
2WD / 4WD
I had a leaky wheel cylinder on my ranger so I pulled it off and replaced it. While I was doing that I figure I might as well replace shoes. Got it all done and the drum is tight on the shoes. I backed off the adjustment screen and opened the bleeder and that helped some but still tight. Never have I had them this tight before. Should I just run it and see if it settles in?
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Did you get the drums turned?
swamprat
3
lexington KY
Engine Type
4.0
2WD / 4WD
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
Betting it's the rabs valve. On my 93 it cost me three sets of rear drums
swamprat
3
lexington KY
Engine Type
4.0
2WD / 4WD
I was bleeding the brakes when I found the leaking cylinder so doubt it is it. Also replaced hard line to that wheel. There is no fluid in cylinder or line going to it
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
It sounds like you may have a set of re-arched shoes.
After market replacement shoes are often built as "re-arched". Basically they make the friction material thicker than it would have been at the factory to account for wear/material removed by machining on old drums. The idea is to return near-factory performance to drums that are near their wear limit.
First turn your adjuster screw in all the way, until you can't compress the shoes any farther by hand. If your drums are still tight that is it. Getting the drums cut, which you really should do anyway for a quality brake job, and they shouldn't be tight anymore.
pjtoledo
2,952
Toledo Ohio
Fords
3.0 2.3
I'll stick my 2 cents worth in here, been there, dealt with it sort of deal.
I've had to customize a couple sets of new rear parts.
first make sure the top of the shoes are against the big pin, and the lowers are fully seated against the adjuster screw. make sure the Ebrake cable is slack and the arm is fully retracted.
put the drum on and tap it a couple times on each side to center stuff. spin it a few turns.
still drag? take the drum off and look for the hi spots. if they are hard to see get a marker and start marking the shoes.
put the drum back on and spin, remove and file down the hi spots. repeat as necessary.
use a long shaving motion, don't file flat spots in the shoes.
once I ground the slot in the adjuster screw a little deeper when only the bottoms were rubbing.
if you have a socket or something the same diameter as the top pin you can lay the pin, shoes, and adjuster screw inside the drum to inspect it.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
The woodworker in me wants to use sticky sandpaper on the inside of the drum lol
pjtoledo
2,952
Toledo Ohio
Fords
3.0 2.3
the metal worker in me has a nice flexible shaving file. works great on round surfaces.
swamprat
3
lexington KY
Engine Type
4.0
2WD / 4WD
The adjustment screw is all the way in. Top of shoes are not closed in on center pin. Leads me to believe the parking brake is stuck. Had parking brake on when I started and released it before I took brakes off.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Make sure the bar isn't getting you jammed up. Then make sure you can't push the shoes in any farther. Don't be afraid to be rough with them.
Bgunner
1,081
Western Mass.
Ford/Ranger XLT
Engine Type
3.0 V6
2WD / 4WD
2WD
225/70/R15
If it's not broken Don't Fix It!
IF the E-Break is not stuck on or adjusted to tightly then it is possible that you may have gotten the wrong size shoes for it. They made two different size drums and shoes for your model. A 9 inch and a 10 inch. It cant hurt to put a tape measure up against the drum to be sure.
9" drums specs:
Maximum Brake Diameter (Discard) (IN) 9.06
Bolt Circle Diameter (IN) 4.5
Bolt Hole Quantity 5
Outside Diameter (in) 10.61
ABS Sensor Ring Included No
Outer Cooling Fins Yes
Bolt Hole Diameter (In) 0.57
Brake Surface Width (IN) 2.17
Center Bore Diameter (IN) 2.54
Construction Composite
Height (in) 2.83
Nominal Diameter (IN) 9
10" drum specs:
Maximum Brake Diameter (Discard) (IN) 10.09
Outside Diameter (in) 11.69
Outer Cooling Fins No
Brake Surface Width (IN) 2.92
Height (in) 3.64
Nominal Diameter (IN) 10
swamprat
3
lexington KY
Engine Type
4.0
2WD / 4WD
They are 10s and drum is 10
pjtoledo
2,952
Toledo Ohio
Fords
3.0 2.3
bingo! at rest they must contact the pin, the springs will pull them in.
swamprat
3
lexington KY
Engine Type
4.0
2WD / 4WD
So I got the drum on last night. I beat on the shoes some and that helped them went to the cable under the driver side and put a channel lock on the piece that connects the cables and pushed towards the rear. Cable moved about .375. Couple taps on shoes and drum slide on. Did other side in about 30 mins. Thanks for the help. Never had an issue before but then again this is first ranger the parking brake worked on. Lol
Staff online
Shran
April Truck of The Month
