A Helpful Guide To Buying Flowmasters
Kowboy
4
Hanover, Virginia
I believe most any 70's-80's trucks would. I had an 80 F150 4x4 that the spare tire got a rock wedged between the tire and the tank and wore a hole in it. It also had a saddle tank. Rust did the side tank in.
turbo2256b
KY, MI, IN, OH
I have a 78 F150 with fender well headers 3" Flowmasters which ever are concidered the quietest. Exh runns outside the frame all the way to the rear bumper. Last trip I TOOK IN IT HAD TO USE EAR PLUGS.
85_Ranger4x4
17,837
SW Iowa
Hmm, didn't know that. Dad's '80 F-350 has the tanks setup like yours but with the spare mounted in the bed like they did with dual tank Rangers. It also has the big spring loaded "farm hitch" that probably displaced the spare from being under the fuel tank. I figured since that is how they did it on dual tank Rangers that is probably how they would do it on dual tank fullsizes as well.
Kowboy
4
Hanover, Virginia
Of course, nothing beats having the gas tank right behind the front seat and in the cab w/ you! I had a 51 Chevy 4 window P-up w/ that set up. I can't remember when the last trucks were built like that.
Kowboy
4
Hanover, Virginia
MastuhWaffles; Now that you've had these for about a year, how do you rate this system. I'm looking at them right now and probably will go w/ a side exit as that is what I had on a 76 F100. Was the install smooth as you expected or were their problems w/ piping or mounts. Looking for a new project.
MastuhWaffles
11/2014 OTOTM Winner
69
Texas
4.0L SOHC
I need more sleep.
Well, I had it done by a shop, it seemed fairly easy, he cut the pipe after the cats, welded on the Flowmaster and hangers and ran piping out the back. If your going to run it out the side than that would be easier, you could run it right after the muffler and out the side and not have to bend it around the back. You can put it where your existing muffler is and use those mounts.
MastuhWaffles
69
Texas
4.0L SOHC
I need more sleep.
Mac
183
C. Wisconsin
2000
199
What's it sound like at cruising rpm's or sound in cabin at speed?
Dave
MastuhWaffles
69
Texas
4.0L SOHC
I need more sleep.
Dave
You can barely hear it around 3k rpm, it gets pretty loud over that, its pretty good though, when you push the pedal down it screams like a v8. I gotta make an acceleration video sometime.
MastuhWaffles
69
Texas
4.0L SOHC
I need more sleep.
