JoanneHWilson
- Aug 1, 2016
- Reaction score
- 0
- Make / Model
- Ford
2008 Ford Ranger 4x4, 4.0 litre
Symptom: Engine bogs down when put under load, ie, Lights, Blower/Heater. Engine eventually stalls.
What we are seeing on vehicle: Right side headlamp(daytime running light) flickering, Instrument panel left side turn indicator faintly flickering. Left turn signal not working front & rear, Blower operating on 1 speed only(slow).
What we have checked/Replaced on vehicle: Alternator replaced,
All ground(Negative) continuity checked, all below 0.5 Ohms,
All connectors checked Engine compartment,
Floor carpet removed from cab & all connectors checked,
All rear bed connectors checked.
All underbody connectors checked.
Both fuse panels checked for corrosion.
We have tried disconnecting the turn signal stick & Hazard flasher from steering column, Same Condition seen.
We have disconnected the Cab center console,Same Condition seen.
We have tried isolating the issue by removing fuses from the Engine fuse panel,Same Condition seen.
We have tried isolating the issue by removing fuses from the Cab fuse panel,Same Condition seen.
