This is how to put block heater in a 4.0.
-Nathan-
Solid Axle Swap
TRS Banner 2012-2015
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
Hey guys, so as my truck came from California, and here in Saskatoon its gets to -50 celsius, I figured I'd put a block heater in. I didn't see a DIY anywhere so I decided to make one.
First things first, remove the air box assembly.
Then, remove the inner fender. Honestly, this was the hardest part of the job, haha.
Here you can see the freeze plug you have to remove.
Now, before you remove it, open your rad cap (make sure the engine isnt boiling hot) and then drain the coolant via the lower rad hose...this makes a big mess.
Then, take a punch or screw driver, and beat in the edge of the freeze plug. Afterwards, just haul it out with a set of pliers.
After the last of the coolant has spewed out, give it a wipe clean, and grab your block heater. Here is the motorcraft one I bought from ford for 35$
Now, take a little bit of NON-petroleum based grease and lube up the o-ring.
Take it, press it into the hole, make sure its seated in the whole way around. Tighten the screw...this opens up the wing nut and makes sure the plug stays in place.
Then plug the end of the cord in and run it through the grille or where ever you like. Put the inner fender back, and then the air box.
Make sure to refill the rad until full, turn on the engine, and let it run WITHOUT the cap on in order to get some of the air out. Top up and then youre ready to go :)
daniel3507
74
NE Oklahoma
Engine Type
2.3 EcoBoost
2WD / 4WD
thats a good write up. much simpler than expected. you'll have to let us know how well it works. whats the part number for it?
caveman_joey
Fitzgerald, GA
stock 4 banger
Very good write up with pics and all... Not that i need it in South GA but still good job! Nice lookin Truck too... clean and simple!
-Nathan-
Solid Axle Swap
39
HO 5.0 / 7.3 PSD
hey thanks, its has a 6" suspension lift and 33X12.50 on 15X10's. Ill update to let you all know how well it works. It was pretty straight forward, but i wrestled with that stupid inner fender forever it seemed.
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number Part number
PLEASE!
AD
Fx4wannabe01
February 2010 OTOTM Winner
OTOTM Winner
20
Boring, Oregon
Ive been wanting to do that for quite some time but was intimidated and never really looked into it. After seeing this how-to....WOW it doesnt look bad at all!
Thanks!!
Allan, I take it you want a part number? lol!!
scotts90ranger
RBV's on Boost
4,309
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
only thing I can say is instead of making a huge mess with the coolant you can get a piece of 3/8" hose of some sort (clear nylon works great) and put it on the drain petcock of the radiator that's on the lower passenger side and put the hose in a bucket and let it drain out, it takes longer this way but you can put the coolant back in if it's usable...
Downey
3
Muncy, PA
ford
4.0
nice write up and damn nice truck
Bas
ford
where the heck is the block heater[cord] on my 2010 4 liter ranger? its suposed to be standard equipment
Fx4wannabe01
OTOTM Winner
20
Boring, Oregon
Look between your grille and radiator. It's not standard equipment, never has been. Always been an option. Unless it's a canada truck(I'm told).
MountainMike
84
Canada
Engine Type
245 CID
2"
31"
The fun begins where the pavement ends
Canadian vehicles require block heaters. Check the lower "smile" opening in the grill or between the grill and bumper.
crbnunit
Solid Axle Swap
247
Anchorage, Alaska
Be careful which freeze plug you knock out. The heater won't fit in all those holes. There is some webbing in the way on some of them. Can't remember which ones. Ask me how I found out... Fortunately, mine was on an engine stand when I made the discovery!
Bas
ford
ye,found it,closer to the driver's side,short cord,well hid.yes it's a canadian truck built in the twin cities
Fx4wannabe01
OTOTM Winner
20
Boring, Oregon
I really wish this thread was up about two months ago! I could've done it with the engine hanging on the picker!!
daniel3507
74
NE Oklahoma
Engine Type
2.3 EcoBoost
2WD / 4WD
im still wanting a part number
Staff online
Shran
April Truck of The Month
