High mount light on topper
86_4x4_longbed
2.3
I have an '04 Ranger and I'm trying to connect my brake light on my topper, but what I have discovered is that my brake and turn signal share a wire. This is only an issue since I don't want my brake light flashing every time I turn left. Any sugestions on where to tap in so I can keep the wires hidden and make it a professional looking job. My only idea was to tap into my high mount on the truck, but it will take a geat deal of wire and then I have to find somewhere to drill to take it out of the cab and back to the bed.
MountainMike
TRS Banner 2012-2015
84
Canada
Engine Type
245 CID
2"
31"
The fun begins where the pavement ends
Can you tap it into the 3rd brake light?
A lot off toppers run a wire along the roof and have a plug that goes into the light socket of the 3rd brake light. Then you put the bulb, into the topper. All you have to do is make sure you seal up the open the open 3rd brake light, a lot of people just drill out a little hole in the bottom of the plastic and run the wire through the tiny hole with a grommet.
86_4x4_longbed
2.3
The plug on my topper is at the left rear corner. I would rather tie in before where brake and blinker become one wire.
martin
26
St Bruno, Quebec
1991
ford
Brake light switch is your only other option.
_BEYONDER_
Are you wired for a trailer? Why not get a plug and tie into the brake light pin on there? It would easily unplug when you take it off.
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
Under your fuse box (underhood one) there will be a green dead-ended wire that is just for this purpose. You will have to run a wire from there to the back of the truck and up into the taillight and into your canopy. It is power from the brake switch at the pedal.
86_4x4_longbed
2.3
Under the fuse box sounds like a great option. I'll Check that out.
86_4x4_longbed
2.3
The brake wire on a 4 flat trailer harness like I have is a brake bliker combo wire. That is why a converter box is required if you have amber turn signals.
Smudgeboss
I cannot find said green wire under the fuse box. As was said before, flat trailer connectors brake line doubles as turn signal for each side. Some other forums have talked about converters so you can hook up to the turn/brake wires for both sides, and it will give a solid non blinking top brake light. any idea where these are available?
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
I have used them before, we have them at work now for doing canopies to save use the time of running wire all the way from the front.
The wire will be under there...did an 08 a couple weeks ago and it was right there.
dark green wire, deadended, with black shrink tube over the end of it.
Smudgeboss
Okay, maybe I have another issue. I had a trailer hookup installed last year. Is it possible that where he came from he hid it or used it for something else, (though in my 7 pin round hookup he shouldn't have an exclusive brake). Mine is an 08 sport, should it be at the back end or under the fuse box?
thanks guys for all your wisdom!
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
If you remove the fuse box it should be in the harness below it.
Smudgeboss
Thanks Saskquatch. Okay, never thought of removing the fuse box. Just a couple of bolts and move it out of the way?
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
Yup, just move it to the side.
Members online
Shran
April Truck of The Month
