HMWhovian
- Nov 5, 2016
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
Hi guys, been a visitor many times before, but now I have an issue I need help with fast. Replaced the front rotors, pads, wheel bearings and wheel seals on my 94 Ranger STX 4x4 Dana 35. In the process of installing the new rotors, I converted my auto-hub lockers with a manual kit I had on my 95 parts truck. Everything went back together smoothly and I made sure that the manual lockers worked by locking them and watching the axle spin and making sure the axle didn't spin in the unlocked position. After putting the tires back on, I went to pull out of my garage and encountered resistance in reverse, like the brakes were bound up. Jacked it back up and spun the wheels no problem. Pulled out of the garage against the resistance and found that she go forward no problem, but clunks if I turn the wheel. Still resists going backwards. Parked it for the night and trying to do some research into this. i did notice that the pass/side lower ball joint had some play, but didn't have time for it today. Any ideas would be greatly appreciated.
