Driver Turn Signal and Brake Light Not Working
jprevat
5
Georgetown SC
2.9 for the time being
Ok I really hope yall can help me out on my 1989 B2.
The turn signals and brake light on my driver side wont light or flash.
I have running lights at all four corners and the relay clicks normally in the dash. However, the indicator light does not light for the driver side either.
I replaced the bulbs and that didnt change anything.
Driver side also will not flash with passenger hazard lights.
I am open to all thoughts. Thank yall ahead of time for your ideas.
CajunPwnStar
Lafayette, LA
2.3L
It's probably an open circuit. I'm not at the computer now, but you need a wiring diagram to trace that driver side circuit.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Probably the turn signal switch.
jprevat
5
Georgetown SC
Thank you for your time. I will have to see if I can come up with some thing. Would you think my short would be between the multifunction switch and the dash light in the steering column or am I looking for connectors under the truck?
jprevat
5
Georgetown SC
That would kill my hazard and brakes for that side? Looks like ill be heading to the pull a' part tomorrow if its not pouring down rain.
Grey_04
50
pennsylvania
ford
4.0
I'd bet your multi function switch is your issue. I had to replace the one in my '03 for similar problems.
jprevat
5
Georgetown SC
Thank you for replying. I guess ill just go ahead and pick one up. Im really hoping this will solve it.
jprevat
5
Georgetown SC
At some point did Ford redesign the multifunction switch? The ones I am finding read "off-1-2-3-4-5-low-high" the one in my b2 currently reads (5-4-3-2-1-off-low-high). Will this new style work for me?
aspevacek
4
Harrisburg PA
4.0 OHV
I would say that is the unit you want for your vehicle.
jprevat
5
Georgetown SC
Wonderful. Thank you for giving me the nudge in the right direction.
Ill answer back once I install and let yall know what happens.
Thank you all again for taking the time to take a look for me.
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
