Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > Mazda B-Series Specific
Mazda B-Series Specific Addressing issues specific to the Mazda B-Series trucks
Reply
Thread Tools Display Modes
Old 04-23-2010, 11:38 AM   #1
T-Bone
T-Bone's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Work and School and Fun
T-Bone is on a distinguished road
Question B2300 EGR Code
Help!! I purchased a 2000 Mazda B2300 with a 2.3, with 110,000 miles on it. The servise engine soon light came on so I took it too the local parts house, they read the code it is a P0401 egr. I went to remove the egr valve and the fitting that attaches to the exhaust system is frozen on there. My question is this, does anyone know if this pipe is a dealer part or can it be purchased aftermarket also. I can see the likely hood of destroying this pipe/fitting and would like to know how or where to get the replacement part if I need it. Attempting to remove this reminds me why I hate working on anything attached to the exhaust sysytem! Thanks for any help.
T-Bone is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 20B2FF503DCF74 Expires: September 28, 2018
Old 04-23-2010, 07:02 PM   #2
martin
Vehicle Year: 1984 1991
Vehicle Make: ford
Vehicle Model: b2 explorer
martin is just really nicemartin is just really nicemartin is just really nicemartin is just really nice
Default
heat it really hot with a torch and then try to move it.
martin is offline   Reply With Quote
Old 04-23-2010, 07:43 PM   #3
Irokranger93
Irokranger93's Avatar
Vehicle Year: 2011
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: DD
Irokranger93 is an unknown quantity at this point
Default
removing egr is just that you go have a light engine is always turn on
__________________
fox racing Baby
Irokranger93 is offline   Reply With Quote
Old 04-26-2010, 07:38 AM   #4
Shawn@BMS
Junior Member
Shawn@BMS's Avatar
Vehicle Year: 95
Vehicle Make: Mazda
Vehicle Model: B2300
Shawn@BMS is on a distinguished road
Default
I had the same deal a few weeks ago on my 2300. I couldn't get the pipe off. I went and did some research on line and it is a common problem. I read many times to take some carb cleaner and spray in the valve. Then get some pliers and manually move the valve shaft up and down to free it. Then i disconnected the battery for a minute to reboot the computer. Worked like a charm and turned off the engine light. Also saved me $50 on an EGR valve i didnt need.
Hope i helped.
~Shawn
__________________
95 Mazda B2300 Pre-Runner.
Shawn@BMS is offline   Reply With Quote
Old 04-26-2010, 08:18 AM   #5
T-Bone
T-Bone's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Default
I'm heading out to the garage now to start working on it. I will try this first. Thanks for the help, I love this site and all of the help that is available. I'll post the results when I'm finished so maybe it can help someone else.
Old 04-26-2010, 11:30 AM   #6
T-Bone
T-Bone's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Smile
Problem solved! Replacing the DPFE(Ford) EGR pressure sensor on my Mazda pick up, and clearing the codes, it repaired my problem of the service engine soon light on accompanied with, hesitation, intermittant high and erratic idle, high idle between gears. Oh yeah a code P0401 also. While removing the sensor, I broke the larger of the two vacuum lines going to the sensor. They were very dry and brittle, so I also replaced the vacuum lines, I cleared the codes, test drove and Wallah never ran better. Thanks to everyone for the help figuring this out.
Old 04-26-2010, 01:18 PM   #7
feellnfroggy
feellnfroggy's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
Its not frozen on(unless your in the middle of a snowstorm right now) The EGR nut is not a typical hex like other nuts. Ford cranks down on this badboy and its kinda oblong. 1 1/8 wrench will fit it if cut in half. The other option I used on a crown vic was an air hammer with a v notch in the flat tip. I hammered it off so to speak. (unscrewed it, didnt break it) The wrench idea is a little easier and if you have body lift makes it a little easier to access.
__________________
This signature has encountered technical difficulties...
Quote:
Originally Posted by Hopman View Post
Like I say to the newbies who join us: "Pull up a chair, grab a cold drink, & watch for low-flying BS!!!!"
Quote:
Originally Posted by Shran View Post
Used to happen to my mom's Grand Marquis all the time when we took it offroad. Don't worry about it.
Agreed. "Whiskey Tango Foxtrot" doesn't begin to cover the ugliness of this thing.
feellnfroggy is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
