93 Ranger 3.0 Engine Races to 3grand briefly and then comes down.
John Regas
Has anyone experienced their Rangers engine constantly racing up rpms to about 3000 and staying there for about ten seconds and then coming back down to a more normal rpm. It seems to happen only in the summer hot and humid months.
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
3.0L
mine does that, but i have a 2.3 and sometimes it will just start idleing 1000 rpm higher then normal. it also idles down when i depress the clutch.........fords are wierd????
almostclueless
3
ford
Mine does it on occasion. I have bought the o-rings that seal the injectors in the intake, thinking they might be causing a vacuum leak, but haven't gotten to replacing them.
Wicked_Sludge
42
Westport, WA
3-point-GO
start with the basics that have already been suggested. check for vacuum leaks (anywhere, not just the injector o-rings). clean your IAC solenoid. also check your throttle cable and plate for any binding/sticking.
Shran
April Truck of The Month
