Tach help
theAntihero
4.0 ohv
My tach has been inoperative since i resurrected my car from years back and id like to have a tach again.
Any links to the wiring of said tach? it worked fine, sat for years and never worked again so im assuming its something simple
DannyG
9
Grand Forks, ND
What exactly isn't it doing? Not moving at all or going up to the 2-3k mark and staying?
I would pull the tachometer module from the cluster and re-solder the contacts on the back. This era is prone to heat stress causing poor connections and solder joint breakage.
