Am I OCD, bored or genius?
Ranger Mark
19
So. Cal
3.0L
Alumni: Hard knocks F.U.
I can't be the only one that has ever thought this, but has anyone ever done it?
I seriously want to color code my engine bay and I wish manufacturers would do this. Using paint, tape, plasti-dip or whatever else I can use.
I mean, as example, all parts that have water will be blue. A/C system parts white. Anything with gas, red. Brake lines and related parts yellow and so on.
Imagine opening the hood of your car, knowing you are working on the brakes and can easily spot all lines and related parts. Oh shit, that was a gas line. Nope, it would be the wrong color and you wouldn't touch it.
To quote a great man.
"I have a dream"
Dirtman
Former Middleweight Moss Fighting Champion
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
I always though color coding bolt sizes would be an interesting idea. But if you're mistaking radiator hoses for brake lines you should probably never ever open your hood lol.:icon_rofl:
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,835
SW Iowa
Engine Type
V8
5.0
John Deere color codes their bulk hardware by grade.
Never really thought about color coding hoses, I don’t think there is much need. I have seen clear pipes so you can see the coolant or whatever travel thru them. Not sure how durable they are though.
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
I recently cut a line I thought was a wire....NOOO, it's a fiber optic line to run light to the PRND1 on the column of a 1980 GMC. FAWCK! Color coding would have really helped. But I don't see the OEM doing this as it would add 1/2 cent to the cost of a vehicle.
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,598
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
A lot of piping systems were color coded on the submarine I was on because once insulated, they really looked alike and size wasn't enough to differentiate things. Steam was white, oil was yellow, oxygen was green, etc. they weren't all colored. Heck. That was way back in the 20th century (1980's). I don't remember all the details. In my truck, the only stuff I really want color coded are the wires although it would be cool with having them all one color as long as each end of each wire had a number on it that corresponded to the wiring diagrams. I work on stuff like that every day.
alwaysFlOoReD
Forum Staff Member
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Kind of my point; oem dont give a shit for the repair, just get it sold. A sub is different in that the navy needs to be able to repair and they have a much larger wallet.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I don't have to imagine. I can do it already. I don't need any color-coded parts.
alwaysFlOoReD
Forum Staff Member
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Adsm08
Remember when you didnt know everything......?
DRanger024
Solid Axle Swap
Ham Radio Operator
GMRS Radio License
482
Dale, WI
Ranger
Engine Type
2WD / 4WD
Solid Axle Swap 4x4
6-7” front maybe 3” rear
Total Drop
33x12.50-15
Agreed. Vehicles are broken down into basic components, everything is traceable and otherwise pretty obvious.
Wiring can be a bear but even if they made wires color coded (they kind of are already), they’d still have different color tracers on each of them. You’d still need diagrams.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Adsm08
Yes I do. I still don't think it would be that helpful, because even when I knew nothing I could tell the difference between wiring, water lines, and brake lines. I might not have known what they were, but colors weren't going to help that, I did know they were different.
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Heh heh. When I did an engine swap a Grand Wagoneer, I spent much time tagging stuff as I took it off. Then I learned that wiring and plumbing under hood is idiot proofed just like appliances. Robots don't plug stuff in,people do. Car harnesses are built to a price point. Extra length isn't allowed. Stretch out the harness. The plug can only be so far away. When I did a head R+R on a Honda CRV, I only matched marked the distributor. The wiring and plumbing went together without a hitch. Everything under a Ranger's hood goes only one place and one place only :D
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
Agreed. The only places that connectors are reused are far enough apart that you can't screw it up. For example, Ford uses matching connectors on the fuel pump and transfer case motor in 99, but you couldn't possibly plug one into the other because of their locations.
Sent from my SM-G960U using Tapatalk
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,835
SW Iowa
Engine Type
V8
5.0
Engine swaps are good to tag. Things don't always line up going together when you mix and match things around.
My neutral start wiring was erroneously calculated as bonus parts and I had to fish thru a bunch of wiring to fix it.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
Where it really gets weird is ford reversing connectors. The giant collector on the drivers side fender that feeds power and several other things into the cab is the exact same on the Ranger and Explorer, but they flip the orientation so you have to cut and solder or repin if you do the swap.
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
2WD / 4WD
If you color coded everything under the hood it would look like those kids toys at the dentist where you push the wooden blocks around the colored wires like a roller coaster. All the different colors going every which way. Most things don't need color coded because you should know that the line coming off the brake cylinder is a brake line or the hose coming out of the radiator is a coolant hose. If OEMS made it easy to work on then the dealerships would lose money. Its a lose-lose to OEMS.
Staff online
Shran
April Truck of The Month
