After all is said and done, I fear my frame is garbage.
askthemasses
Seattle, WA
ford
3.0
Replaced my grill today and noticed this when I took off the old one.
Welllllll bummer. Popped the hood and took a look from the top
Lemme guess- frame is shot? needs to get weld repaired? I don't even know if I should be driving on this.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
We looking inside the back of the bumper? looks to me like bumper was hit, bent, replaced, but they did not bend the bumper bracket back into place if that's your only problem you're good to go you, it can be fixed.
You wouldn't believe the rust on my truck!
askthemasses
Seattle, WA
ford
3.0
I'm more worried about the GIANT CRACK down the middle of that piece in the first pic. The car was for sure hit at some point- the bumper sags and it has a dent on the driver corner. I missed this damage though. The second picture shows that this cracked piece is attached to the frame.
Better orientation of pictures.
Looking down, facing engine bay
Under car
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I'd take it to a frame shop and get an estimate. It may be worth repairing if the rest of the truck is in good shape.
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,704
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
Doesn't look like the end if the world to me. That's way out in front of anything real important and it should be fixable. If it was mine, I would look for other damage and have the alignment checked. If it can be aligned or is still aligned within spec, the rest of the frame probably isn't tweaked bad enough to worry about. Make sure the engine mounts aren't damaged. If in doubt, have a good body/frame shop check it out.
This message composed solely of recycled electrons. Go green!
JamesH
If that just the end where the bumper bolts on it's no big deal... Smack it back on place and weld it up, the crack is on the end cap, like they said if it's still alignable don't fret, justake sure the bumper won't fall off.
Sent from my Moto Z (2) using Tapatalk
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
yeah....not an issue if you deem it not worth funding or wasting effort to repair till our good and damn well ready.
Dirtman
Former Middleweight Moss Fighting Champion
13,328
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
I concur. I see no "real" frame damage. The frame rail itself does not appear damaged just the bumper bracket. I wouldn't lose any sleep over that unless the truck has alignment issues indicative of a bent frame rail.
scotts90ranger
RBV's on Boost
4,445
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
Both my Ranger and F350 crab walk down the road, I know what caused the Ranger issue, no idea on the F350 (346k on the clock, I've only put 25k of that on it...), that isn't anything to worry about. That's just the bumper bracket, hammer it back out so the bumper can be bolted on right and call it good, no need to weld up that seam on the top, it won't do much...
Today's birthdays
Mudtruggy
May Truck of The Month
