Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > 4WD Systems
4WD Systems Transfer Cases & Locking Hubs.
Reply
Thread Tools Display Modes
Old 01-20-2011, 11:04 AM   #1
fenderville
fenderville is on a distinguished road
Default 2000 Ranger 4.0 - 4x4 will not engage
Howdy all..
I have a 2000 Ford Ranger with a 4.0 Automatic.
I can't get the 4x4 to engage.. It did engage but after about a mile it disengaged itself.. Then it will not go back in..
I tried it from a dead stop.. I tried High.. I tried low
Won't engage at all now..
Any ideas what this could be?
Thanks!
fenderville is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-20-2011, 03:11 PM   #2
feellnfroggy
feellnfroggy's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
Sounds like it aint the motor but something else. Maybe a meltedvacuum line?
__________________
This signature has encountered technical difficulties...
Quote:
Originally Posted by Hopman View Post
Like I say to the newbies who join us: "Pull up a chair, grab a cold drink, & watch for low-flying BS!!!!"
Quote:
Originally Posted by Shran View Post
Used to happen to my mom's Grand Marquis all the time when we took it offroad. Don't worry about it.
Agreed. "Whiskey Tango Foxtrot" doesn't begin to cover the ugliness of this thing.
feellnfroggy is offline   Reply With Quote
Old 02-04-2011, 10:26 AM   #3
fenderville
Default
Is there a way to trace the vacuum hose that is the culprit?
Old 02-05-2011, 09:50 PM   #4
swamper
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger Splash
swamper is on a distinguished road
Default
What is not engaging transfer case or front hubs
swamper is offline   Reply With Quote
Old 02-06-2011, 01:45 AM   #5
Original_Ranger84
Original_Ranger84's Avatar
Vehicle Year: 1984, 1999
Vehicle Make: Ford
I use this vehicle for: Project, DD
Original_Ranger84 is a jewel in the roughOriginal_Ranger84 is a jewel in the roughOriginal_Ranger84 is a jewel in the rough
Default
Do you know if it has hubs or a live axle? The way I figure out which vacuum lines on mine were not working was by pulling the air filter housing and right down by the frame there should be a vacuum port. one to each hub and one to the pump. I hooked up a vacuum gauge to each of the hubs tubes and pumped it up to 25 mmhg to see if the hubs were holding the vacuum and then the gauge hooked up to the pump to see what kind of vacuum it was pulling, which should vary from 19 - 21 mmhg and then 25 - 27 mmhg. Also note that the orings by the hubs tend to leak as well.
__________________
99 Ranger DD - 3.0L, 5spd, 4x4, 4 door, step side, 31's, 4x KC driving lights.
84 Ranger Project - 2.8L, 5spd, 4x4, regular cab, long bed, 3" body lift, 31's, 4x KC long ranges, Dual CD player/Blaupunkt Speakers.
Quote:
Originally Posted by Myself View Post
"Tall Trucks, Small trucks, whos got the balls to roll with our trucks?"
Original_Ranger84 is offline   Reply With Quote
Old 02-23-2011, 04:18 PM   #6
fenderville
Default
I am not sure if it is hubs or a live axle...
The other day I tried it again.. It seems that it goes in to low... but not into 4x4...
I slected 4x4 low and it reved way up when doing 20mph like it should but it didn't have 4 wheel drive.
Then I turned the nob to 2 wheel and it would not disengage.. . I had to keep turning on and off and backing up and forward...
Old 02-23-2011, 05:42 PM   #7
Earl43P
Premium Member
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: a driveway ornament, light hauling
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
Does the front drive shaft turn when you engage 4wd?
No=transfer case problem.
Yes=vacuum hub problem.
If it has a large nut in the center of the lugnuts, it is live axle and has no front hubs (not PVH). If it has that, you have a transfer case problem.
To shift from 4Lo to 4Hi/2Hi you must stop, foot on brake, shift in N or P. Clutch in/stopped/brake on for a 5 speed. 2Hi to 4Hi and back, just flip the switch anytime.
__________________
If at first you don't succeed, RTFM.
82 GL1100 Bratbike
93 GL1500I DD
99 Valkyrie IS
08 Rav4 Sport "boring"
Earl43P is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
