liamkeough88
So I'm in the process of finishing up installing a 2 inch body lift on my 88. Was attaching the steering shaft extension and was having some difficulty fitting it over the shaft so gave it a few taps with a mallet to help slide the extension all the way up and onto the shaft. Anyways, after a few taps the shaft shot up several inches into the firewall. I managed to pull it back out (somewhat) but it is still pushed back more than it was before the whacking began. Should I be worried about this? I'm not sure if the shaft is designed to telescope like that or if I knocked something out of place. Any tips on getting the shaft to pull back out the way it was?
thanks in advance.
thanks in advance.
