Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > Mazda B-Series Specific
Mazda B-Series Specific Addressing issues specific to the Mazda B-Series trucks
Reply
Thread Tools Display Modes
Old 02-09-2011, 12:36 AM   #1
mazda3000
Junior Member
mazda3000's Avatar
Vehicle Year: 1997
Vehicle Make: Mazda
Vehicle Model: B3000
I use this vehicle for: anything
mazda3000 is on a distinguished road
Default losing clutch fluid
Ok so it been loosing some fluid for a while now but it seems to do it wen ever it wants to. for example, yesterday i had to pump the clutch every time i wanted to shift and today it worked perfect, dident lose a single drop. i looked all over and cant seem to find wear its going. the master cylinder was changed 2 years ago along with the clutch and the slave and hoses were changed last year.
any ideas on whats going on. its got me puzzled
mazda3000 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 02-09-2011, 05:06 AM   #2
sfwjesse
sfwjesse's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Hauling stuff, some mudding
sfwjesse is on a distinguished road
Default
sounds like your slave is going. Are you actually seeing the level in the reserviour drop? Pull the rubber plug out of the view port on your bell housing and reach up there with your finger and feel the bottom of the inside. If you find brake fluid....its time to pull the tranny.
sfwjesse is offline   Reply With Quote
Old 02-09-2011, 05:42 PM   #3
ForOffRoadDriving
ForOffRoadDriving's Avatar
Vehicle Year: 1994
Vehicle Make: FORD
Vehicle Model: RANGER
I use this vehicle for: EVERYTHING A RANGER CAN DO, AND LOTS OF THINGS IT SHOULDN'T
ForOffRoadDriving has a spectacular aura aboutForOffRoadDriving has a spectacular aura about
Default
mines been doing this lately too, but i am losing fluid slowly (i fill add 1/4" or twice a week, when it gets really cold) and i can see brake fluid residue on the quick connector, so im thinking its the o-ring, maybe it has a tear or is shrinking when its really cold out? its annoying, but i hope it makes it through the winter as i dont want to deal with it right now.
__________________
1994 Ranger 4X2 Off Road, Built Not Bought!
http://www.therangerstation.com/foru...ad.php?t=37621
ForOffRoadDriving is offline   Reply With Quote
Old 02-09-2011, 10:40 PM   #4
mazda3000
Junior Member
mazda3000's Avatar
Vehicle Year: 1997
Vehicle Make: Mazda
Default
I'm hopeing its not the slave, i got that changed in the summer. it does lose a fair amount of fluid wen it starts to act up. mine seems to bee doing it wen its cold to (colder then like -15ish). i was talking to a guy here today and he said that it could be the o ring. ill crawl under the truck tomorrow and try to see if i can find were the leak is. can that o ring be changed without pulling the trany?
Old 02-09-2011, 11:22 PM   #5
ashleyroachclip
Vehicle Year: 1994 Ranger STX
Vehicle Make: 1995 Explorer L
ashleyroachclip is on a distinguished road
Default
The O ring can be changed without pulling the tranny.
I suspect your trouble is , not that you are loosing fluid but you have air in the system.
I went thru this until I found the video that showed how to bench bleed the system and get the trapped air that hides in that crooked mess of line beside the frame rail
ashleyroachclip is offline   Reply With Quote
Old 02-10-2011, 12:13 AM   #6
mazda3000
Junior Member
mazda3000's Avatar
Vehicle Year: 1997
Vehicle Make: Mazda
Default
im almost sure its not air. ive put close to 3 containers of brake fluid in it since it started doing this. i should of filled that void by now.
Old 02-10-2011, 10:02 AM   #7
ranger
Vehicle Year: 1988
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: waisting gas and money
ranger is on a distinguished road
Send a message via AIM to ranger
Default
my 88 is doing the same thing and i was told i needed a new slave
__________________
88 ranger 4x4 2.9 5 speed
7inches of lift, 33x12.50's, custom exhaust and intake 4.0 clutch swap and 4.10 gears
ranger is offline   Reply With Quote
Old 02-10-2011, 11:25 AM   #8
ForOffRoadDriving
Vehicle Year: 1994
Vehicle Make: FORD
Default
it did it to me again this morning, it was 1*F outside and when i depressed the clutch to engage the neutral saftey switch it felt fine, but after letting it warm up for 5 min i pushed in the clutch and put it into gear and as soon as i started to let out the clutch it just lunged and then stalled out. i pumped it a few times, but didnt get any pressure so i popped the hood, removed the resevoir cap, then pumped it a few times and the pressure was restored. i refilled the resevoir to the step and reinstalled the cap and made the trip to work without any troubles from the clutch. how annoying this is becoming!
__________________
Old 02-10-2011, 05:33 PM   #9
mazda3000
Junior Member
mazda3000's Avatar
Vehicle Year: 1997
Vehicle Make: Mazda
Default
it is very annoying and it seems to come and go. like the other day was the first time it leaked in over a month. i used it all day today and it dident leak a drop. i was gonna crawl under the truck today and try to find the leak but i had way to much stuff to do so ill try to get under there tomorrow. it better not be my dam slave going again. ive changed it twice in the 3 years ive had the truck.
Old 02-10-2011, 05:56 PM   #10
ranger
Vehicle Year: 1988
Vehicle Make: ford
Default
mine is probably the slave because its about 8 years old. And i was told by my buddy that owns a garage that it was the slave
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
