Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Brakes
Reply
Thread Tools Display Modes
Old 02-15-2011, 12:28 AM   #1
5.0gray90'
Junior Member
5.0gray90''s Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Ranger
5.0gray90' is on a distinguished road
Default Brakes soft, pedal goes all the way to the floor. 2001 4.0L
The brakes in my 2001 4.0L 4x4 ranger are soft and the pedal goes all the way to the floor when braking. it stops, but it doesnt stop like it should. Has anyone had this problem, or know any solutions. I cant see any brake fluid leaking, the only thing i suspect is a wheel cylinder in the back, would that cause this problem?
__________________
2001 Ranger XLT 4.0L 4x4
5.0gray90' is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 02-15-2011, 01:00 AM   #2
3.0ranger1227
3.0ranger1227's Avatar
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger Edge
I use this vehicle for: DD, playing in the sand
3.0ranger1227 will become famous soon enough3.0ranger1227 will become famous soon enough
Default
bleed the system... is the reservoir full?
__________________
2003 Edge 2WD 3.0, Camburg Performance 6.0 dual shock, SSBC rear disc brakes
Red Stepside
4.3L on the way!
3.0ranger1227 is offline   Reply With Quote
Old 02-15-2011, 10:12 AM   #3
5.0gray90'
Junior Member
5.0gray90''s Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Default
yes the reservior is full.
__________________
Old 02-15-2011, 10:27 AM   #4
TechmanDan
Junior Member
Vehicle Year: 2002
Vehicle Make: Ford
I use this vehicle for: Everything
TechmanDan is on a distinguished road
Send a message via MSN to TechmanDan
Default
From the top, check:
Master Cylinder, filled to correct level.
Check consistency and color of fluid, compare to new fluid.
Check vacuum home connection from intake to power booster. (Make sure it's connected on both ends and in good condition)
Check your wheel cylinders/calipers for damage or leaks.
Check your pads/shoes for wear (note any inconsistent or odd wear for later).
Check the brake mechanisms for anything out of place (damage, cracks, missing parts/bolts/pieces etc.)
Clean your rotors and drums with some form of brake cleaner (NOT 409 or other household cleaners).
If you do all of that and don't find anything, the problem is in your mind
But if you do get there, bleed the system twice. Bad brakes and nothing damaged means air in the system.
__________________
Daniel
KI4WIN
2002 Ranger XLT 4x4
4.0 SOHC V-6
TechmanDan is offline   Reply With Quote
Old 02-17-2011, 01:08 PM   #5
mht95ranger
mht95ranger's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
I use this vehicle for: Winter and towing the jet ski in the summer
mht95ranger is on a distinguished road
Default
My 95 did the same thing and it turned out to need pads.. The caliper pistons were so far out and the caliper slide pins were frozen.
__________________
95 ranger 4x4 4.0 auto extended cab. 168,000 miles
Please don't laugh at it it is my winter beater
mht95ranger is offline   Reply With Quote
Old 02-18-2011, 09:21 PM   #6
5.0gray90'
Junior Member
5.0gray90''s Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Default
just replaced the back shoes, a wheel cylinder in the back, and front pads. then bled the system. seems to stop better, but i can still push the pedal to the floor. it stops alot better. i can only push it to the floor when the engine is running tho, not when it is shut off.
__________________
Old 02-19-2011, 07:19 AM   #7
BeefStew42791
BeefStew42791's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger STX Longbed
BeefStew42791 is on a distinguished road
Default
The ONLY way this can happen is with a slight leak or with air in the lines somewhere. I would recommend you
(1) take a nice, objective, critical, long look of EVERYTHING in your system. Look for some discoloration that makes the part look wet and there's your area (obviously if you just washed it this isn't the wet I'm talking about).
(2) If you determine there is in fact not a leak in the system, then bleed it bleed it and bleed it. Start from the back passenger side wheel, then to the driver's side rear wheel, then to the passenger side front wheel, and finally the driver's side rear wheel. If this doesn't fix the problem, see step 1.
__________________
Mods: 3" BL, Hedman headers, custom catback duals w/ Magnaflow muffler, Sony deck, 130amp Explorer alt., 31's, & a SMOKIN HOT BUG GUARD!!
http://therangerstation.com/forums/s...ad.php?t=47773
BeefStew42791 is offline   Reply With Quote
Old 02-26-2011, 05:28 PM   #8
289-tiger-
Vehicle Year: 1994
Vehicle Make: Ford
289-tiger- is on a distinguished road
Default
Check to make sure the bleeder screw is above the brake hose upon installation of calipers (L vs.R), it will help the air out of the system when the brakes are bled.
Good luck
289-tiger- is offline   Reply With Quote
Old 02-27-2011, 12:39 PM   #9
Ranger44
Ranger44's Avatar
Vehicle Year: 1995
Vehicle Make: FORD
Vehicle Model: Explorer
I use this vehicle for: Riding mad max style......
Ranger44 will become famous soon enough
Send a message via AIM to Ranger44
Default
Just for shits and giggles....with the truck off pump the pedal till it's stiff. Hold your foot on the pedal and start the truck. Does the pedal drop?
Any fluid behind the master cylinder? Unbolt it and pull it back a little. See if the seal is blown.
Other than that make sure the line by the gas tank doesn't have a pin hole in it. They like to corrode back there.
Also when bleeding the system use brand new fluid and let it gravity bleed till it's clean. Brake fluid is highly hydroscopic. It will pull moisture from the atmosphere if left open or unsealed. Moisture is bad in a brake fluid system cause when it heats up it turns to air.
Other than than that...make sure the pins aren't frozen in the caliper bracket and that the hoses aren't bulging when the brakes are applied.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark.
Giddywomp Offroad & Fab
Ranger44 is offline   Reply With Quote
Old 02-27-2011, 04:20 PM   #10
289-tiger-
Vehicle Year: 1994
Vehicle Make: Ford
Default
It really sounds like he has the calipers reversed.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
