Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 02-25-2011, 06:39 AM   #1
1badexplorer
1badexplorer's Avatar
Vehicle Year: 97,79,00,72,71
Vehicle Make: Ford
Vehicle Model: Ranger, F250, F350, Mustang, Bronco
I use this vehicle for: waste all my money
1badexplorer is on a distinguished road
Default runs rough no power p0174 code
I've been having issues with my ranger for the past coupl days. I'm running out of ideas. I think I may have it narrowed down but I would like to get other opinions before I do anything else.
Ok, here is some background on the truck. Its a 97 Ranger 3.0 5spd. Just turned 180,000 miles. It has never given me any major problems until now. It is 100% stock.
It runs rough and has a miss from right off idle untill around 3,000 rpm. It gets worse if the motor is under load. I've had to do alot more downshifting than normal. It is worse on gas than normal. I scanned the CEL and it gave me p0174. Bank 2 lean (drivers side) I've cleared it several times and it still has a miss and after 10-25 miles the CEL comes back on. Sometimes the miss is hardly noticable while other times its terrible. It starts up like normal and doesn't stall or anything like that either.
Here is what I've done in the past two nights. I swapped out the coil pack with 2 different spares I had, neither made any difference. My plugs and wires were only about 6 months and 10,000 miles old. But I changed the plugs again anyway. 5 of the plugs looked normal and white but the back cylinder (#6) on the drivers side was black and carboned up. So I figured that is the cylinder that has the problem. I then changed fuel filter and ran a pressure test. I have 40psi @ the rail. I'm suppose to be between 35-45psi. I then cleaned the MAS and IAC sensors. That didn't help either. I checked the air intake tube for cracks and it is good. I then spayed several cans of starting fluid around the gasket areas of the upper and lower intakes and on all the vaccum lines I couldn't find any leaks. I do not have any exhaust leaks before the o2 sensors either. I then started thinking maybe my plug wire coule be bad. So I swapped the one from the cylinder #6 with a wires from a parts truck. Nither of the wires made a difference.
I'm running out of options as to what it could be. I doubt it is an o2 sensor causing this. I'm thinking that it's the injector but I could be wrong. I don't know of any way to test these and I don't want to just change it on a hunch. I'll have to pull the upper intake to swap it and I'd like to avoid buying gaskets and wasing time wrenching if it's not the problem.
If it is the injector, could I swap in one from a 94 4.0 engine? I have a whole set from a parts truck.
__________________
00 F350 Dually Crewcab 4x4 7.3 6spd
79 F250 501BBF,4spd, d60, 10.25 38s
49 F-16at Cummins 5spd bagged ratrod
72 Mustang Mach1 351C, 4spd
71 Bronco d60, 14bt, 351efi, 4spd,203/205, 44s beadlocks plus lots more
1badexplorer is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 02-25-2011, 08:55 AM   #2
JP02XLT
JP02XLT's Avatar
Vehicle Year: 02
Vehicle Make: Ranger
Vehicle Model: XLT
JP02XLT is on a distinguished road
Default
Seems like you have done of good job of eliminating everything but the injectors, I would try to unplug the injectors while the truck is running & note the difference in how it idles, unplug one & the idle should get rougher, however if the injector is sticking or leaking like I think your seeing on #6 it could idle better for a second or so. Sometimes unplugging the injector can cause them to cycle harshly an possibly to dislodge a small obstruction. The other thing you could do is move the injector to another cylinder & see if the problem moves with the injector in question. If you do get it clear itself with unplugging the connector, I would strongly consider running some E-85 through it as well, 4-5 gallons of e-85 added to 3/4 tank of gas would be good cleaner for the fuel system & will not bother anything.
JP02XLT
__________________
BowTie Killer
JP02XLT is offline   Reply With Quote
Old 02-25-2011, 09:30 AM   #3
1badexplorer
Vehicle Make: Ford
Default
I never thought about trying to unplug it. It would be a PITA to just swap it with anotehr cylinder. The way the upper intake is made it covers the injectors on the drivers side. If I have to pull the intake I'm just going to change the injector. Whether it be a used 1 from the parts truck or 1 from a parts store.
__________________
Old 02-25-2011, 10:46 AM   #4
JP02XLT
JP02XLT's Avatar
Vehicle Year: 02
Vehicle Model: XLT
Default
Yeah I hear you on it being covered, just was not sure how your 3.0 looked compared to mine, hopefully better, but does not sound like it.
Good luck, These can sometimes be a real pain to figure out.
JP02XLT
__________________
BowTie Killer
Old 02-26-2011, 02:23 AM   #5
bg@f.ord
Junior Member
bg@f.ord's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger Edge 3.0 cranked with 31's cambered & aligned.1 of a kind.Chrome/white front.Pic soon........
I use this vehicle for: Wife taxi
bg@f.ord is on a distinguished road
Default
Do compression test on back cylinder (#6) on the drivers side.i'll pray 4 u
bg@f.ord is offline   Reply With Quote
Old 02-26-2011, 03:50 AM   #6
Rearanger
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger 3.0L
Rearanger is on a distinguished road
Default
Quote:
__________________
2003 3.0L Long Box, 5spd Manual, 2wd, 3.73 LS,
P235/70R-16, Synthetic fluids, 91.5k miles
Rearanger is offline   Reply With Quote
Old 02-26-2011, 06:57 AM   #7
1badexplorer
Vehicle Make: Ford
Default
Yea, thats what I'm going to do before I tear the intake off.
__________________
Old 02-27-2011, 06:54 PM   #8
1badexplorer
Vehicle Make: Ford
Default
Ok, so I did a compression test and everything was good. So I than changed #6 injector and it cleared up and runs great.
__________________
Old 03-11-2011, 11:02 PM   #9
bg@f.ord
Junior Member
bg@f.ord's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Default
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
