Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > 4WD Systems
4WD Systems Transfer Cases & Locking Hubs.
Reply
Thread Tools Display Modes
Old 02-28-2011, 03:39 PM   #1
xerofuzzion
Vehicle Year: 1999
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Daily Driver & Off Road + Everything Else
xerofuzzion is on a distinguished road
Default bypass 4x4 control module?
I searched though the forums and i don't think this has been asked yet.
Is there a way to bypass the 4x4 control module?
Someway to wire it so that when you flip the switch it'll switch into 4Hi or 4low?
__________________
1999 Ford Ranger XLT 4x4 3.0L V6 Manual 5spd
-AVM Hubs -3" PA Body Lift -33x12.5 Enduro's -15x10 Eagle Alloys -Added Power Windows&Locks+Keyless entry
xerofuzzion is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 02-28-2011, 03:54 PM   #2
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
I don't think so...
Maybe if you could rig up some indicator lights to the sensor contacts that would light up when the motor is at the various positions and you had two momentary pushbuttons (each spins the motor in the opposite direction) you might be able to do it, but it'd be far easier to just swap a manual case in (or maybe put something like the Shiftster knob on it).
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 02-28-2011, 04:06 PM   #3
exbass94
exbass94's Avatar
Vehicle Year: 2006, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Pavement Poundin'
exbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really nice
Default
No. The transfer case motor is a "stepper" motor. Stepper motors need a controller (the control module) to operate. It's not as simple as connecting a positive and negative wire and a switch.
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 63k miles
1994 Ford Explorer Sport 2-dr 4x4, 203k miles
1992 Honda Accord EX, 182k miles
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek, 33k miles (wife's)
exbass94 is offline   Reply With Quote
Old 02-28-2011, 04:13 PM   #4
feellnfroggy
feellnfroggy's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
different voltages and resistances make this an almost impossibility, just do a manual tranny swap.
__________________
This signature has encountered technical difficulties...
Quote:
Originally Posted by Hopman View Post
Like I say to the newbies who join us: "Pull up a chair, grab a cold drink, & watch for low-flying BS!!!!"
Quote:
Originally Posted by Shran View Post
Used to happen to my mom's Grand Marquis all the time when we took it offroad. Don't worry about it.
Agreed. "Whiskey Tango Foxtrot" doesn't begin to cover the ugliness of this thing.
feellnfroggy is offline   Reply With Quote
Old 02-28-2011, 04:58 PM   #5
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Make: Ford
Default
Quote:
Must be different on the '95up cases, both of mine use ordinary DC (brushed-type) motors much like the motor for your power windows. The motor is "bumped" into position by very brief clicks of the controller's relays.
A stepper motor does indeed require a controller to operate.
__________________
'90 Bronco II XLT
'94 Ranger XLT
Old 02-28-2011, 05:24 PM   #6
hondaxr650
Vehicle Year: 1997
Vehicle Make: Ford
hondaxr650 will become famous soon enough
Default
Someone recently posted about how they had done but it requires running straight battery power to the motor and starting/stopping the motor manually with a switch by guessing when it's in the right position. Sounds like a good way to grenade a perfectly good t/case to me.......
hondaxr650 is offline   Reply With Quote
Old 02-28-2011, 11:32 PM   #7
xerofuzzion
Vehicle Year: 1999
Vehicle Make: Ford
Default
Damn, i was hoping there would be a simple solution, I guess the best way would be to find a manual T-case and switch it out.
__________________
Old 03-01-2011, 08:08 AM   #8
tanbuddy
tanbuddy's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
I use this vehicle for: D.D. 4 wheeling, hauling
tanbuddy is on a distinguished road
Send a message via AIM to tanbuddy Send a message via Yahoo to tanbuddy
Default
ive done it on my truck, but only tempory when the t case motor acts up. I just unplugged the motor, and spliced in 2 wires for + and - and ran them into the cab, Give them power and ground and the t case will shift, i leave the truck off and window open to hear it move. When it stops your in 4 lo, reverse the polarity and its 2 hi. Its hard to hit 4 hi cause its in the middle, it usually takes a few trys.
__________________
1989 Ext cab XLT 2.9, FM146, Electric 4x4
Upgrade 4.0 clutch, 4.10 LSD, manual hubs 15x7 ford wheels, 31BFGs, 2" lift/traction bars hack job exhaust/intake
2000 explorer sport stock
tanbuddy is offline   Reply With Quote
Old 03-01-2011, 09:58 PM   #9
gribly
gribly's Avatar
Vehicle Year: 2002
Vehicle Make: Honda
Vehicle Model: EP3 Civic Si
gribly is a glorious beacon of lightgribly is a glorious beacon of lightgribly is a glorious beacon of lightgribly is a glorious beacon of lightgribly is a glorious beacon of light
Default
The stock setup works fine, if it's in good shape. The problems are usually in the gearcase attached to the motor, the worm drive. There is a little bushing on the stop pin, and it breaks. When that happens, the worm drive can go too far and lock up in 2wd.
__________________
"If at first you don't succeed, use more duct tape." - Uncle Red
"I can't feel anything, but I can't stand up!" - Tina
gribly is offline   Reply With Quote
Old 03-01-2011, 11:26 PM   #10
xerofuzzion
Vehicle Year: 1999
Vehicle Make: Ford
Default
My t-case is fine, its just the control module that malfunctions.
Usually ill flip the switch to go to 4hi (while in neutral and pressing the brake) and ill hear a couple of clicks, then the 4hi & 4low lights will flash on the dash board. I will then disconnect the battery and reconnect it and i will try the switch again and itll switch easily.
Is there a way to maybe cut off the sensor signals or something? I'm guessing the control module receives signals from sensors and if all are correct, itll tell the t-case to shift? Is there a way to maybe cut off the sensor and send the right signal on command with a switch or something?
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
