Coil spacers
scheetz21
hello, im wondering if i put coil spacers under my ranger if i need to do anything besides align it. then if i want original stance, put 2 inch shackles in back?? thanks in advance butch.
legoms013
09/2013 OTOTM
OTOTM Winner
Solid Axle Swap
26
CA
4.0L V6
No all you'll need is an alignment afterwards.
For the rear, a set of Beltech shackles will perk it up about 1.5". If you need more than that get a AAL or another block.
shane96ranger
222
Utah
Ford F150-Stang
Engine Type
V8
4.6 Triton / 5.0
What are you planning on using for coil spacers? About everyone on here will steer you away from anything but washer stacks. I have a set ready to go into mine right now. I'm into them about 20 bucks with the can of spray paint. Here's a pic:
Surrey
10
Vancouver, Canada
2.9
Just make sure you buy washers that are big enough. 1 3/8" inside diameter is what you want I think...
I bought smaller than that, and now have to use a drill and grinding stone to make the holes a bit bigger, because they dont clear the bolt head on the bottom of the bolt that screws into the axle beam and holds the spings. I could have just bought more washers, but that was more expensive then a $4 grinding stone. for 14 washers, total cost was about $15, although Im only planning on using 6 per side (the extra two are to level it out if needed)
dirttrackracer
Law Enforcement
Solid Axle Swap
9
Bloomsburg, PA
4.0
how safe is that? and reliable? long story i bent my 3in lift couls and i have stock back on front. and i want to levil it back out.
legoms013
09/2013 OTOTM
OTOTM Winner
Solid Axle Swap
26
CA
4.0L V6
Washers as spacers are completely safe, even un-welded. Don't let anyone tell you that they are not.
Everyone and their brother here on TRS has run them at one time or another for the last 10 years with no problems.
:icon_thumby:
shane96ranger
222
Utah
Ford F150-Stang
Engine Type
V8
4.6 Triton / 5.0
I only welded them because I saw a video that had them welded on youtube. I agree though, they would be fine without welding them.
sfwjesse
New Hampshire
4.0
safe enough.....ive been running them for a few years now...havent budged.
scheetz21
oh well its not worth buying the 50 dollar ones off ebay??? and how much higher is the back than the front?? 2 in?
rkneeshaw
7
Northern Michigan
4.0L
1-3/8" nominal size washers actually have a ID of about 1-5/8".
1-1/4" nominal size washers actually have a ID of about 1-3/8".
I'm going to use fastenal's website to make sure I get the exact size I need based on ID and OD measurements.
Can someone confirm they are 1-3/8" ID that we need, and not 1-3/8" nominal size washers?
rkneeshaw
7
Northern Michigan
4.0L
Yes, thats exactly what I wanted to confirm, thank you!
The tech article mentions 1-3/8" washers, and then later specifies a 1-3/8" ID.... which, as you have pictured, are two different things. Obviously whats important is that the ID is 1-3/8 and OD is 3", which is a 1-1/4" nominal size washer.
railman
December 2011 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
12
Madisonville, KY
4.0
legoms013
09/2013 OTOTM
OTOTM Winner
Solid Axle Swap
26
CA
4.0L V6
Washers are the way to go, the daystars deteriorate, and the aluminum ones crack. Don't even get me started on the rubber ones that "thread" into the coil windings.
Similar threads
Staff online
Today's birthdays
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
