Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-21-2011, 08:10 AM   #1
skyjack
Vehicle Year: 2001
Vehicle Make: Ford
Vehicle Model: Ranger XLT 4x4
skyjack is on a distinguished road
Default 2001 3.0 Cylinder Head Torque
Can anyone set the facts straight here on the proper cylinder head torque specs for a 2001 3.0 Ranger? One method is the 5 step (37 ft lbs, loosen 1 turn, 22 ft lbs, 90 degrees, 90 degrees).
Method 2:
1. Step 1: 59 ft. lbs. (80 Nm).
2. Step 2: Loosen the bolts one full turn.
3. Step 3: 40 ft. lbs. (55 Nm).
4. Step 4: 63 ft. lbs. (85 Nm).
I have a torque rotation meter, and would put it to good use here if necessary. So which method is recommended by Ford for the 01 Ranger? Thanks!
skyjack is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-24-2011, 01:31 PM   #2
mattswan267
Junior Member
Vehicle Year: 2002
Vehicle Make: Ford
I use this vehicle for: Off Road
mattswan267 is on a distinguished road
Send a message via AIM to mattswan267
Default
I just rebuilt my 1999 ranger 3.0 and if I remember right the head bolt torque was something like
step 1: 27 ft/lb
step 2: loosen 1 turn
step 3: 73 ft/lb
mattswan267 is offline   Reply With Quote
Old 03-24-2011, 02:15 PM   #3
stmitch
March 2011 STOTM Winner
stmitch's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: Surprising people
stmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of light
Default
My Haynes manual says to follow method 2 as you posted for all 99 and up 3.0's. Except it gives ranges for steps 3 and 4. For step 3, it says torque to 34-40 ftlbs, and for step 4, it says 63-73 ftlbs. Make sure you follow the proper torque sequence as well.
stmitch is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
