Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 04-06-2011, 07:33 AM   #1
rkneeshaw
rkneeshaw's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Winter beater, wheelin with my son
rkneeshaw will become famous soon enough
Default tools needed for changing ball joints
On my 94 4x4 I need to change the drivers side ball joints.
I understand I'll need:
Ball joint press
4-prong spindle nut socket
snap ring pliers
But I only have wrenches and sockets up to 18mm on hand and will need to buy larger size wrenches if I need them.....
Anyone know what size wrench I'll need to get the top and bottom ball joint nuts off?
__________________
1994 Ford Ranger 4.0L 4x4
3.5" of James Duff Stage 1 | 32x11.5x15 BFG AT's | 15x8 cragars | stainless brake lines
Sony and Kenwood sound | gen4 seats | tow hooks | procomp fogs
[ Build thread ]
rkneeshaw is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 04-06-2011, 07:41 AM   #2
--weezl--
June 2011 OTOTM Winner
--weezl--'s Avatar
Vehicle Year: 2007
Vehicle Make: Ford
Vehicle Model: Ranger FX4 Level II
I use this vehicle for: stealing candy from babies, and sometimes driving to work
--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute--weezl-- has a reputation beyond repute
Default
21mm i believe it is...
read this page, it has everything you want to know, should be the same style everything (i hope)
http://www.cfht.hawaii.edu/~grant/ra...t/install.html
__________________
Quote:
Originally Posted by Insanejughead View Post
Don't worry Weezl, if you're banned I'll petition to have you brought back.
Quote:
Originally Posted by multiranger View Post
I asked my girlfriend to measure it for me.. It's only an inch
check out my build thread
--weezl-- is offline   Reply With Quote
Old 04-06-2011, 07:55 AM   #3
rkneeshaw
rkneeshaw's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Default
Na, thats a 2000, which has a newer suspension style. My truck has the older TTB style, but I believe its not exactly the same as the older pre-90 broncos....
__________________
[ Build thread ]
Old 04-06-2011, 07:59 AM   #4
--weezl--
--weezl--'s Avatar
Vehicle Year: 2007
Vehicle Make: Ford
Default
ohhhh, damn... lol
give me a moment i'll get you more info...
edit:
* HOME
* REPAIR INFO
* 1994 FORD TRUCK RANGER 4WD 4.0L MFI 6CYL REPAIR GUIDE
* SUSPENSION & STEERING
* 4-WHEEL DRIVE FRONT SUSPENSION
* BALL JOINTS
1. Check and adjust the front wheel bearings. Raise and support the vehicle.
2. Have a helper grasp the lower edge of the tire and move the wheel assembly in and out.
3. While the wheel is being moved, observe the lower spindle arm and the lower part of the axle jaw.
4. A 1 / 32 in. (0.8mm) or greater movement between the lower part of the axle jaw and the lower spindle arm indicates that the lower ball joint must be replaced
5. To check the upper ball joints, while the wheel is being moved, observe the upper spindle arm and the upper part of the axle jaw.
6. A 1 / 32 in. (0.8mm) or greater movement between the upper part of the axle jaw and the upper spindle arm indicates that the upper ball joint must be replaced
REMOVAL & INSTALLATION
Except Mountaineer, 1995-99 Explorer and 1998-99 Ranger
The ball joints are arranged such that if the upper ball joint is to be removed, the lower ball joint must be removed first. Also, when installing the upper ball joint, the lower ball joint must be installed first. Failure to install the lower ball joint before the upper, will result in a lack of clearance for the installation tool.
1. Remove the steering knuckle.
2. Place knuckle in vise and remove snapring from bottom ball joint socket if so equipped.
3. Assemble the C-frame, T74P-461-C, forcing screw, D79T-3010-AE and ball joint remover T83T-3050-A or equivalent on the lower ball joint.
4. Turn forcing screw clockwise until the lower ball joint is removed from the steering knuckle.
5. Repeat the previous steps for the upper ball joint.
Always remove and install the lower ball joint first
To install:
6. Clean the steering knuckle bore and insert lower ball joint in knuckle as straight as possible. The lower ball joint doesn't have a cotter pin hole in the stud.
7. Assemble the C-frame, T74P-461-C, forcing screw, D790T-3010-AE, ball joint installer, T83T-3050-A and receiver cup T80T-3010-A3 or equivalent tools, to install the lower ball joint.
8. Turn the forcing screw clockwise until the lower ball joint is firmly seated. Install the snapring on the lower ball joint.
If the ball joint cannot be installed to the proper depth, realignment of the receiver cup and ball joint installer will be necessary.
9. Repeat the previous steps for the upper ball joint.
10. Install the steering knuckle.
The ball joints on the Mountaineer, 1995-99 Explorer and 1998-99 Ranger are integral with the control arms. If the ball joint is defective, the entire control arm must be replaced. Refer to the appropriate control arm removal & installation procedures later in the section.
however....... a little bit of searching would have turned up this thread for you ;) last post was the day before yesterday too lol
http://therangerstation.com/forums/s...d.php?t=106006
__________________
Old 04-06-2011, 10:57 AM   #5
rkneeshaw
rkneeshaw's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Default
well thats good info on the procedure, but I think I've got that covered.
I'm looking to see if anyone can verify what size wrenches i'll need for those ball joint nuts. 1-1/8" or 1-15/16"? bigger? smaller? I only have up to 18mm on hand so I'll need to go pick up the right size before I start the job
__________________
[ Build thread ]
Old 04-06-2011, 11:20 AM   #6
--weezl--
--weezl--'s Avatar
Vehicle Year: 2007
Vehicle Make: Ford
Default
did you check the thread i posted a link to?
i'm about 99% sure it's bigger than 21
__________________
Old 04-06-2011, 11:53 AM   #7
chrwilkins30
chrwilkins30's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: running over hondas
chrwilkins30 will become famous soon enough
Default
Im 95% sure the ball joint nut us a 24mm.
__________________
88 bronco II94 4.0|3inBL|4in SJ lift|1354M|8.8/d35 w/4.56 R&P|M5od swap|Ex leaves|35 km2|classic Locks|Bushwacker Flares|JD tire carrier
Still NeedSliders|winch|snorkel|F250 towers
MY BUILD
WTBShifter Bezel like thishttp://i1090.photobucket.com/albums/...gershifter.jpg
chrwilkins30 is offline   Reply With Quote
Old 04-06-2011, 11:57 AM   #8
Surrey
Surrey's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
I use this vehicle for: Raisin' Hell!
Surrey will become famous soon enoughSurrey will become famous soon enough
Default
I know what tool you need!
Calipers!
__________________
My Bronco II Build - http://www.therangerstation.com/foru...d.php?t=103061
1989 Bronco II Eddie Bauer ed. 2.9l v6, a4ld automatic.
Surrey is offline   Reply With Quote
Old 04-06-2011, 12:13 PM   #9
88_Eddie
Chopper Challenge Champion
88_Eddie's Avatar
Vehicle Year: 1988, 2000
Vehicle Make: Ford
Vehicle Model: Bronco II (Eddie Bauer), Explorer
I use this vehicle for: Annoying the old ball and chain.
88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute
Default
on the lower BJ has a castle nut on it, i think it's a 13/16, i cant remember. i just finished attaching my knuckles to my d35, i cant remember right now.
i'd get an impact gun as well. i used a cheap eletric one that i got when i worked at autozone (the manager was gonna throw it away). it makes using the BJ press 100 times easier.
i'd get some PB blaster as well
and as always, a BFH
__________________
BUILD THREAD<<<<<<<<<<<<<
The Tikki Torch Build Thread
1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now)
2000 Explorer 4.0 2WD DD
Everything I need to know about Islam, I learned on 9/11.
The hardest part about a zombie apocalypse will be pretending I'm not excited.
Quote:
Originally Posted by Wedding Crashers
What'd you do with them? Motorboat? You play the motorboat? You motorboatin son of a bitch! You old sailor you!
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
88_Eddie is offline   Reply With Quote
Old 04-06-2011, 12:35 PM   #10
rkneeshaw
rkneeshaw's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Default
According to this its a 1-1/8" wrench, but this is on a Bronco and my lower ball joints are listed for only 93-97 rangers/explorers/navajos so I'm not sure thats reliable
http://www.off-road.com/trucks-4x4/t...ent-18945.html
I guess I can just see what nut is on the new ball joint when I get it and hope its the same size as what's installed in the truck now....
I read the whole thing through, but I didnt see where it stated what size wrenches to use.
I'm not worried about the top because that pinch bolt looks smaller than 18mm anyway so I'm sure I'll get that one, its just the lower.
I've got lots of PB blaster, pneumatic impact, a BFH, but I think I'm going to take the knuckle to a shop to have them press out the old ball joints/press in the new ones just so I dont have to buy a ball joint press, i'll just borrow a buddies car. Should take them all of 15 minutes tops IMO.
__________________
[ Build thread ]
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
