Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Non-Ranger Axles
Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc.
Reply
Thread Tools Display Modes
Old 02-07-2008, 06:42 PM   #1
ZSK
ZSK's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: F-150
ZSK is on a distinguished road
Default F250 vs F150 D44 TTB
Aside from the F250 being leaf sprung and the F150 being coil sprung are there any major differences from the knuckles in? I'm looking into building a cheap wheeling rig now that I have a good DD/towrig. I've got a 93 F150 as a starting platform. I blew out the auto hubs on stock 235/75/15's and figure I can pick up some F250 D44 beam and possibly D50 parts for cheaper than manual hubs alone. I'm also thinking that F250's will be geared a little better 4.10's vs my 3.55's.
__________________
Past:
1996 Ext. Cab 2wd XLT 4.0 auto, Flowmaster 40, K&N, Jet Chip, AAL, Rough Country 4" lift with 31's and 4.10's
Present:
2004 F150 Crew cab 5.4 2wd auto
ZSK is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 02-07-2008, 07:46 PM   #2
projectnitemare
projectnitemare's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger XLT
projectnitemare will become famous soon enoughprojectnitemare will become famous soon enough
Default
Aside from being 8 lug a HD 44 isn't any stronger than it's 5 lug couterpart. Even worse in that case the leaf sprung HD 44 uses completely different beams that aren't coil compatible (same for the D50TTB). What you want to look into is making your D44 into a D44/50 hybrid. The 50 uses D60 outer stubs and hubs. That will make your weak link the 3rd member of the D44.
Matt
__________________
88 Ranger XLT 4x4, finally in process: Custom frame, extended cab/shortened bed hybrid, exocage, 396W stroker, 77mm turbo, C6, twin stick 205, 2.5 tons, 4 links....build thread coming soon
projectnitemare is offline   Reply With Quote
Old 02-08-2008, 09:23 AM   #3
ZSK
ZSK's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Default
Interesting D50/D44 hybrid similar to what Todd did on the D44/D35 hybrid.
__________________
Past:
Present:
Old 02-08-2008, 09:52 AM   #4
CopyKat
CopyKat's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: BroncoIV
I use this vehicle for: DD/Wheeler
CopyKat is on a distinguished road
Default
The D50 beams are the same as the D44HD beams.
The D50 pig will bolt to a D44 beam.
The D50 side gears have the same spline count as the D44 shafts.
CopyKat is offline   Reply With Quote
Old 02-08-2008, 05:12 PM   #5
Evan
Evan's Avatar
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Explorer Sport
I use this vehicle for: Wheelin
Evan is on a distinguished road
Default
Quote:
Matt
Does the 50 have the same outer kunckles as a 60?
__________________
2001 Mustang Cobra SVT convertible: 5-speed, 320HP V8, 0-60 in 4.8
2009 Chevy Aveo 5-door LS: 5-speed, DD
Evan is offline   Reply With Quote
Old 02-08-2008, 05:53 PM   #6
CopyKat
CopyKat's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
Quote:
No on the knuckles but....
I believe the spindle cone/rotor/hub is.
Old 02-08-2008, 06:40 PM   #7
Evan
Evan's Avatar
Vehicle Year: 1991
Vehicle Make: Ford
Default
So, the outer shaft has a D60 spline count, but it has an ear that takes a D44/35 joint?
I'm only asking these questions because I have a crazy idea in mind...
__________________
Old 02-08-2008, 08:52 PM   #8
CopyKat
CopyKat's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
The Joint on the D50 is the same size and style as the D60 The D44 HD uses the same D44/D35 joint.
The down side of the D50 is the neck down when it goes into the Diff. The spline there is the same as a D44.
Easy to make a D44/D50 hybrid. Use a regular D44 beam and axle ends. Swap in the D50 center section and keep the D50 center joint as it will adapt to the D44 axle shafts.
The D44 knuckles are different than the D44HD so doing a knuckle swap will be more involved due to the shear size of the D50 axle shaft joints.
Old 02-08-2008, 09:13 PM   #9
PARKINGLOT
PARKINGLOT's Avatar
Vehicle Year: 1995
Vehicle Make: Jeep
Vehicle Model: Grand Cherokee
I use this vehicle for: haulin' groceries & wheelin'
PARKINGLOT is on a distinguished road
Default
but aren't there more locker options and stuff for a D44 center section vs/ D50 center section?
__________________
RIP Matt C - turbonator/sohc86 :(
Switched to the dark side - 95 ZJ 5.2 with some stuff.....
"I don't break shit, I just test it's durablity"
Formerly GONRACIN, Member #166, Join date 30-July 04
PARKINGLOT is offline   Reply With Quote
Old 02-12-2008, 09:34 PM   #10
projectnitemare
Vehicle Year: 1988
Vehicle Make: Ford
Default
I thought it over before, I know what your crazy idea was because I thought of it already; make a D35/50 hybrid. The D50 shaft uses D60 size u-joints it just necks down at the pig to a D44 size spline.
Matt
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
