Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > Exhaust
Reply
Thread Tools Display Modes
Old 04-13-2011, 08:25 PM   #1
Sevensecondsuv
Sevensecondsuv's Avatar
Vehicle Year: Many
Vehicle Make: All Fords!
Vehicle Model: Most of what Ford Made in the 90s!
I use this vehicle for: Life
Sevensecondsuv is on a distinguished road
Default New true dual exhaust - now what is resonating so bad?
Hi all:
**LEGAL: The subject truck is used off-road only and is therefore emissions exempt**
I just finished putting true duals on my '92 explorer. I cut the factory Y-pipe apart and added some bends to it to get dual 2-1/4" pipes running right next to each other along the passenger side of the transmission. They run about 4 feet and then end in a 2-1/4" X-pipe. From there, dual 2-1/4" pipes run over the axle and in to dual thrush welded (knock-off Flowmaster 40) mufflers. The mufflers have turn downs half cocked to each side.
Anyways, at idle, it sounds great, with a very deep, pulsating rumble. From about 3000 RPM to redline, it once again sounds awesome, pretty much the best sounding six I've ever heard. My complaint is 1500-3000 RPM, where something starts resonating terribly. It's resonating so bad that it sounds like one of the pipes is rattling on the frame of the truck. I've checked and double checked all clearances and have at least 3/4" everywhere, so it's not rubbing.
Anyone have any suggestions? I'm thinking maybe I should put some glass packs in the 4' section before the X-pipe...
__________________
2011 Ford Ranger 2.3 5-spd; 2001 Ford Ranger 2.5 5-spd;
1992 Explorer 4wd 5-spd; 2000 Ford Excursion 6.8 4wd;
1995 Ford F-250 4wd 4.9 ZF-5 D60 SAS;
Past: 1990 Ranger 2.3 Turbo
Sevensecondsuv is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 04-13-2011, 08:33 PM   #2
Surrey
Surrey's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: Raisin' Hell!
Surrey will become famous soon enoughSurrey will become famous soon enough
Default
Ahhhhhh, I love how emissions exempt means the environment doesn't matter anymore...
If you are going to put something on there, I would do some universal cats over glasspacks.
__________________
My Bronco II Build - http://www.therangerstation.com/foru...d.php?t=103061
1989 Bronco II Eddie Bauer ed. 2.9l v6, a4ld automatic.
Surrey is offline   Reply With Quote
Old 04-13-2011, 08:53 PM   #3
BlueChariot
BlueChariot's Avatar
Vehicle Year: '94
Vehicle Make: Mazda
Vehicle Model: B4000
I use this vehicle for: everything
BlueChariot is just really niceBlueChariot is just really niceBlueChariot is just really niceBlueChariot is just really nice
Default
A cow does many times the environmental damage of a car's exhaust, so could we not split hairs over emmissions?
__________________
'94 Mazda B4000 Sport, stock for now.
Can't wait to start back to school soon. Gonna earn my living welding. I can see lots of fabricating in my future.
BlueChariot is offline   Reply With Quote
Old 04-13-2011, 09:06 PM   #4
Sevensecondsuv
Vehicle Year: Many
Default
Quote:
Your 2.9L breathing through cats has worse emissions than a 4.0L without cats - it's a proven fact (and also why 4.0L's didn't even have EGR for the first couple years). If you care that much, you should consider driving something newer and cleaner.
__________________
Old 04-13-2011, 09:28 PM   #5
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
May be because the exhuast exits under the passenger compartment of the truck?
May also be a V6 being a V6? My 2.8 used to like to drone a lot with a louder exhaust, kinda made me decide the best sounding V6 is one you can barely hear (in my case to know if it was still running) With just a glasspack it sounded neat at idle, and at higher RPM, but really just noisy with no definition between, it had pipe running out behind the rear passenger side tire. That setup didn't stick around too long... my solution was more muffler.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0 HO wannabe, C5 Transmixer, 31 spline T/L 8.8 w/ disc brakes.
Build Thread
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is offline   Reply With Quote
Old 04-13-2011, 10:22 PM   #6
blackwidow67
The Vengeful One
blackwidow67's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: RANGER
I use this vehicle for: pissing my neighbors off
blackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to allblackwidow67 is a name known to all
Default
just extend the pipes out a lttle further. dumps resonate the exhaust under the truck. running the pipe all the way out will eliminate this.
and will sound better.
__________________
1988 RANGER. Built 355 SBC. TH700R4. 3:73 Gears. BlackWidow Clone
1990 RANGER. Mild 5.0. T5 trans. 4.10 gears. Daily driver!
2002 Dakota 5.9 R/T QUAD CAB. for work and play....... well mostly play
1962 CHEVY IMPALA SS CONVERTIBLE
1999 DODGE RAM 1500. Lifted. 33s. 5.9. Magnaflow exhaust. Tow rig!
blackwidow67 is offline   Reply With Quote
Old 04-13-2011, 10:28 PM   #7
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Vehicle Year: 1988
Vehicle Make: FORD
Vehicle Model: RANGERISH SORT OF THING
I use this vehicle for: EVERYTHING
My credo: it is easier to fix and understand than "her"
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
or run two different size mufflers. or add resonators
i assume you have 20 psi of boost with that exhaust system on that 450 hp engine so i can see where its a mystery as to why it resonates. it seems the turbo should quiet it a little through those echo chambers.
err...
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Old 04-13-2011, 10:38 PM   #8
177CIOfPureLove
177CIOfPureLove's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: DD
177CIOfPureLove is on a distinguished road
Default
Quote:
I am not going to disagree with your statement, Although something I found really shocking was when my 2.9 passed state emissions with fully hollowed out converters. I had just swapped it in my truck, it had 127,000 miles and I had done a full tune up on it as I swapped it in. I had ordered new cats but had not gotten them yet, just wanted to bring it up so it would fail, and drive around on my rejected sticker until they were installed. You would not believe the surprise I had when the guy scraped my old sticker off and put a new one on. I had passed with flying colors. 1988's don't even have EGR valves! I had to take all that stuff off of the motor (a 1986) before I put it in!
__________________
1989 Ranger XLT Long bed- (DD)
2.9L / M5OD R1 4x2. 172,000 miles.
1999 Mustang GT 35th Anniversary (#129 of 4,628) Performance Red, 61,000 miles
1981 Volkswagen Rabbit Pickup, 1.6 L Diesel 62,000 miles.... 50mpg...
(Sold)1988 Ranger STX Ext. Cab 2.9L manual 4x4 FM146
31" tires, 2" lift, 1 piece d/s, 3:73 op/ls
177CIOfPureLove is offline   Reply With Quote
Old 04-13-2011, 10:54 PM   #9
Hahnsb2
Hahnsb2's Avatar
Vehicle Year: 88-95
Vehicle Make: Ford-Dodge
Vehicle Model: BII-Dakota
I use this vehicle for: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
This.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Old 04-14-2011, 04:46 PM   #10
Daven
Daven's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Daven will become famous soon enough
Default
I figured this kind of fit with his question so i thought i should ask it for both of us lol... How much will running it out the back effect the sound? Will it lose/add some rumble or anything?
Many people on here say they like the turndowns and i was considering doing that when i do my exhaust. But if it is pretty mucht he same thing without so much drone-ing, i wont lol.
__________________
Quote:
Originally Posted by greenbean93 View Post
You can burn a Ranger, crash a Ranger, and break a ranger, but you just can't kill them. Gotta love em.
"When in doubt, ALWAYS quit your job"
Daven is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
