Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > 4WD Systems
4WD Systems Transfer Cases & Locking Hubs.
Reply
Thread Tools Display Modes
Old 08-22-2007, 08:22 PM   #1
bigpotato555
bigpotato555's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Ranger
bigpotato555 is on a distinguished road
Default dual transfercase
hey i where looking to make a dual transfer case with a BW1350 and BW1354 i look in the tech library but the info there is limited... i wonder if anyone as done one and if they have detail pics..thx
__________________
Big
2004 Pontiac Sunfire, cold air intake
1989 Ford Ranger 2.9L, cold air intake, accel ignition, headers,M50d-R1,BW1350, 4.0L centerforce 2, 4.10 gear lincoln locker rear,4" rough country, 2" coil spacer, 2" shackle, 2" body lift and 33" tsl swamper on 10" wheels or 36" military on grand prix wheels and 10 000 lbs champion winch
www.edmundston4x4.com
bigpotato555 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-22-2007, 08:40 PM   #2
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
There are some kits available for building the dual 1350/1354 cases now.
A bare-bones kit, but includes an all-new solid 1-pc chromo coupling shaft (requires procuring the 2nd case yourself)
http://www.pirate4x4.com/forum/showthread.php?t=465032
A complete ready-to-assemble kit (also is about " shorter, if you're real tight on rear driveshaft room)
http://www.4-x-fab.com/Stubler_info.php
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 08-22-2007, 08:47 PM   #3
bigpotato555
Vehicle Year: 1989
Vehicle Make: Ford
Default
i know the 350$ kit is pretty cheap but going to university is not...lol is there a do it yourself way costing next to nothing?thx again
__________________
Big
Old 08-22-2007, 09:05 PM   #4
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Make: Ford
Default
'fraid not...
The cheapest way to do it is probably going to be what's described here
Expect to spend probably around $100-150 getting a shaft done, and another $100-150 on another case.
__________________
'90 Bronco II XLT
'94 Ranger XLT
Old 08-22-2007, 10:06 PM   #5
bigpotato555
Vehicle Year: 1989
Vehicle Make: Ford
Default
i like this way i already have a tcase and a friend of mine have a machine shop for the shaft thx a lot dude
__________________
Big
Old 08-22-2007, 11:49 PM   #6
Stumpy
Stumpy's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Stumpy is on a distinguished road
Default
Does anyone have any experience with the "stubler"?
It looks all bolt on, pretty basic set up.
Can anyone explain how it works without affecting 2wd for the street?
I'm having a hard time getting my mind around it.
(sorry if I am jacking the thread!)
__________________
1990 Bronco II, 3.5" James duff, 3" Body lift, 33x12.5's, 3-chime air horn, racing buckets, lock-right.
http://www.cardomain.com/id/Stumpy3
Stumpy is offline   Reply With Quote
Old 08-23-2007, 12:46 AM   #7
Hahnsb2
Hahnsb2's Avatar
Vehicle Year: 88-95
Vehicle Make: Ford-Dodge
Vehicle Model: BII-Dakota
I use this vehicle for: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
It works just like a regular transfer case, you shift it in and out of low... Therefore it doesnt affect street use.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Old 08-23-2007, 02:19 AM   #8
baddis
Premium Member
baddis's Avatar
Vehicle Year: 1997 2000
Vehicle Make: Ford Ford
Vehicle Model: Explorer Ranger
I use this vehicle for: dd and having fun
baddis has a spectacular aura aboutbaddis has a spectacular aura about
Default
does it have to be a 1354?i have a manual and 2 electric 1350 tcases. and one of the 1350 cases has the bolt on yoke like the 1354. it is in an 88 stx high rider
__________________
IF IT ISN'T BROKE I HAVEN'T TRIED
baddis is offline   Reply With Quote
Old 08-23-2007, 11:31 AM   #9
arrabil
Vehicle Year: 1990
Vehicle Make: Ford
arrabil is on a distinguished road
Default
Why did Jim add a note saying not to shift the Toddler into low while keeping the TC in high? The Stubler instructions specifically mention this as a benefit of a dual case setup and I have a place where it would be useful to me.
__________________
1990 Bronco II 2.9L M5R1 BW1354e 5.13 D35/arb 8.8-31/arb 35s +6". The Deuce.
2006 F-150 5.4L 4R75E BW4406e 3.73 8.8-28/open 9.75/open 33s.
arrabil is offline   Reply With Quote
Old 08-23-2007, 05:23 PM   #10
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Make: Ford
Default
If the Stubler mentions that (I didn't look it over real well), then that's just asking for breakage.
If the doubler is in LO with the rear case in HI, all the torque multiplication from the 1st gear reduction will be on the coupler shaft. At a mere 1" spline diameter, it is not up to handling that much torque.
There would NO benefit from this either, the doubler and rear case have the same ratio, so best just put the rear case in low first.
Any combination of 1350 and 1354 cases can be used, although its FAR easier to find a manual 1350 case than a 1354 to use as the doubler box (plus, cutting apart a rare 1354 manual case is likely to make you some enemies too lol)
__________________
'90 Bronco II XLT
'94 Ranger XLT
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
