Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 04-30-2011, 03:02 PM   #1
SU8ZERO
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger XLT 2.3L 4Cyl
SU8ZERO is on a distinguished road
Default Oil in spark plugs
I have a 2002 4 cyl 2.3l ford ranger that got oil in the middle 2 spark plugs, theres a sensor inbetween those 2 plugs which is where i think the oil is coming from but am not sure, any help would b appreciated
SU8ZERO is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 05-01-2011, 06:24 AM   #2
press 1 for english
press 1 for english's Avatar
Vehicle Year: 2007
Vehicle Make: Ford
Vehicle Model: Ranger XLT Supercab Blue
I use this vehicle for: Pleasure...drive to work
press 1 for english will become famous soon enough
Default
Quote:
Oil in the spark plugs???? What do you mean by that?
__________________
Dumb is an art form!
press 1 for english is offline   Reply With Quote
Old 05-01-2011, 09:54 AM   #3
Ranger beater
Ranger beater's Avatar
Vehicle Year: 2005
Vehicle Make: Ford
I use this vehicle for: Everything
Ranger beater is on a distinguished road
Default
Do you mean on top of the spark plugs? I had a similar problem and it turned out that the valve cover gasket was leaking.
Ranger beater is offline   Reply With Quote
Old 05-01-2011, 11:41 AM   #4
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ext Cab, 4WD, Auto, 4WABS, AC, 140k/90k.
modelageek will become famous soon enough
Default
Pic?
__________________
2004 Ext Cab, 4WD, 4.0, Auto, 153k(engine is out of a 2009 Ranger with 95k) Mileage readings as of 5/14/2017
2004 Ford Ranger Edge, Ext Cab, 2WD, 3.0, 5 speed, 116,000, AC. (SOLD)
1999 Ford Ranger, Reg Cab, 2.5, 5 speed, 2WD, no AC, 150k (SOLD)
modelageek is offline   Reply With Quote
Old 05-03-2011, 09:54 AM   #5
SU8ZERO
Vehicle Year: 2002
Vehicle Make: Ford
Default
my truck wasnt idleing right or running right so i took out the plugs an at the bottom of the plugs where they ignite the fuel was dripping with oil when itook them out.
Old 05-03-2011, 11:42 AM   #6
Rogue_Wulff
Vehicle Year: 1995
Vehicle Make: Mazda
Vehicle Model: B2300
Rogue_Wulff will become famous soon enough
Default
Most likely the valve cover leaking. When oil leaks at the plug holes, it will puddle around the plug until it's removed, then it runs down the threads of the plug and into the cyl.
It's not the main (outer) gasket that leaks, but the 4 smaller inner gasket/seals around the plugs holes.
Pretty common issue on any engine that has the spark plugs in the middle of the valve cover.
__________________
95 B2300 RCSB 2.3L M5OD 3.45
83 Mazda RX7 1.1L Rotary 5 speed
80 F150 Ranger Explorer 4.9L C6
74 F100 Ranger XLT 390 C6 1 owner (Dad bought new)
Rogue_Wulff is offline   Reply With Quote
Old 05-03-2011, 09:30 PM   #7
nb11
nb11's Avatar
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger xl
I use this vehicle for: A-B
nb11 is a jewel in the roughnb11 is a jewel in the roughnb11 is a jewel in the roughnb11 is a jewel in the rough
Default
Had the same problem a while back with mine. Pulled the plugs and said holy crap I'm burning oil worse than Iran circa 1990!!!!!! Then I realized that it's impossible to have oil on the threads, and that its the oil pooling up around the plugs. Is there oil built up on the front of the engine too? Mine has some, so I know my gaskets are leaking and it's only a matter of time...
nb11 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
